Intel® Makers
9882 Discussions
Intel Galileo Gen 2 sketch.elf[1325]
SArbo
Hi, I´m running a sketch on my intel galileo gen 2 and after 4 hours working i get this error in the galileo terminal:
[17262.080992] sketch.elf[1325]: segfault at 48 ip b7637db5 sp bfc2c828 error 4 in libuClibc-0.9.34-git.so[b7605000+75000]
Then the sketch stops and i have to restart it, nevertheless the galileo keeps working normally. The sketch uses this c++ libraries:
# include
# include
# include
# include
# include
# include
# include
# include
# include
The Galileo is running SDCard.1.0.4 OS downloaded from http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000005614.html Software Downloads for Boards and Kits and it already has the firmware update 1.0.4.
Thank you in advance.
FTinetti
Honored Contributor I
Hi sebaz_143,
Do you have any example to reproduce the error?
Would it be possible you have any memory leak?
Fernando.
SArbo
The only way i can reproduce the error is waiting, i thought it could be a memory leak, but i don't have many variable in my sketch.
Sometime i think it could be becaouse i use a File output stream every 2 seconds but i'm not sure. I also have in my sketch a server socket listener running all the time. That's why i posted the libraries i'm using, maybe somebody has experiment a memory leak with one of those libraries. The sketch also use the millis() function. But i tried to be carefull with the memory, so almost all varaibles are declared with CALLOC and deleted with FREE().
Thank you!
FTinetti
Hello again,
Maybe I didn't explain correctly: please post the "minimum" example to reproduce the error in my card.
Fernando.
Carlos_M_Intel
Hi sebaz_143
Do you have updates? Could you post a part of the code you are using so we could test this?
Also, which image are you using on your board? Run the command uname –a
Charlie
SArbo
I´m working on it, the error its a segmentation fault and one of the troubles is the use of the millis() function. I already translate all my code to c/c++ in eclipse, it's less memory consuming.
FTinetti
I do not understand why the use of the millis() function would be a problem...
Fernando.
