Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel Galileo Gen2 is unable to connect to the network
Jump to solution
Hi All,
My Intel Galileo Gen2 board is unabale to connect to the network.I refer to the Getting Started-Ethernet,but I'm unable to get its IP address. I try to do the command:ifconfig eth0 up,ifconfig .But it doesn't work.
Accepted Solutions
Highlighted
Re: Intel Galileo Gen2 is unable to connect to the network
Jump to solution
Hi Kernaly,
In order to connect your board to wireless you need to have the LINUX IMAGE FOR SD and the wireless card connected to your board.
You can download the SD card Linux image here: https://www-ssl.intel.com/content/www/us/en/do-it-yourself/downloads-and-documentation.html# galileosoftware https://www-ssl.intel.com/content/www/us/en/do-it-yourself/downloads-and-documentation.html# galileosoftware
You can see how to set up the wireless card here http://www.intel.com/support/galileo/sb/CS-035091.htm http://www.intel.com/support/galileo/sb/CS-035091.htm
Then, you need to enter the terminal and in the command prompt type the command: ifup wlan0.
If you want to use the Ethernet interface you need to make sure that your board is in the same network as the rest of the network you want to connect to.
You can use the command ifconfig eth0 netmask up.
Sergio
Highlighted
1 View
Jump to solution
Hi Kernaly,
Sergio
Highlighted
Jump to solution
Thank you for your help.Now it works.
