Intel® Makers
9873 Discussions
Intel Galileo gen2 SPI pin configuration issue
AJain22
I am trying to configure the galileo gen 2 SPI pin 10-13. After executing the following script it shows error as can not set direction for gpio72, gpio74.
SCRIPT::
# !/bin/bash -e
# v0od0ochild
echo "Configuration Spidev1.0 for Galileo-Gen2.."
# pin10
echo 26 > /sys/class/gpio/export || echo "gpio26 already exported"
echo 74 > /sys/class/gpio/export || echo "gpio74 already exported"
echo 27 > /sys/class/gpio/export || echo "gpio27 already exported"
echo low > /sys/class/gpio/gpio26/direction || echo "Failed to set gpio26 low"
echo low > /sys/class/gpio/gpio74/direction || echo "Failed to set gpio74 low"
echo in > /sys/class/gpio/gpio27/direction || echo "Failed to set gpio27 direction in"
# pin11
echo 24 > /sys/class/gpio/export || echo "gpio24 already exported"
echo 44 > /sys/class/gpio/export || echo "gpio44 already exported"
echo 72 > /sys/class/gpio/export || echo "gpio72 already exported"
echo 25 > /sys/class/gpio/export || echo "gpio25 already exported"
echo low > /sys/class/gpio/gpio24/direction || echo "Failed to set gpio24 low"
echo high > /sys/class/gpio/gpio44/direction || echo "Failed to set gpio44 high"
echo low > /sys/class/gpio/gpio72/direction || echo "Failed to set gpio72 low"
echo in > /sys/class/gpio/gpio25/direction || echo "Failed to set gpio25 direction in"
# pin12
echo 42 > /sys/class/gpio/export || echo "gpio42 already exported"
echo 43 > /sys/class/gpio/export || echo "gpio43 already exported"
echo low > /sys/class/gpio/gpio42/direction || echo "Failed to set gpio42 low"
echo in > /sys/class/gpio/gpio43/direction || echo "Failed to set gpio43 direction in"
# pin13
echo 30 > /sys/class/gpio/export || echo "gpio30 already exported"
echo 46 > /sys/class/gpio/export || echo "gpio46 already exported"
echo 31 > /sys/class/gpio/export || echo "gpio31 already exported"
echo low > /sys/class/gpio/gpio30/direction || "Failed to set gpio30 low"
echo high > /sys/class/gpio/gpio46/direction || "Failed to set gpio46 high"
echo in > /sys/class/gpio/gpio31/direction || "Failed to set gpio31 direction in"
echo "SPI Ready"
After executing the above script getting the following error,
./spi11.sh: line 10: /sys/class/gpio/gpio74/direction: No such file or directory
./spi11.sh: line 20: /sys/class/gpio/gpio72/direction: No such file or directory
SPI Ready
Anshul
Pedro_M_Intel
Hello anshul.jain,
I'm currently working on very similar thread ( ), I should update it soon, why don't you wait for my reply there?
Peter.
n_scott_pearson
Super User Retired Employee
Anshul,
You have posted your query in the support community for Intel's Desktop Board products. You won't get much traction here. I suggest that you re-post your query in the Galileo support community (here: ).
Pedro_M_Intel
Hello anshul.jain,
Peter.
