My Intel Joule was showing the initial bootup screen (F2 to do this,...)
After I enabled one of the option (" boot every 500ms"), it stopped to even show this initial startup screen.
What can I do to reset it back to factory setting?
-weehyong
To add, the first 2 green leds light show up, with a blue led flash.
After that, only the power LED is on.. and there is nothing on the screen.
Hello WeeHyong,
Thanks for reaching out!
Could you please let us know the steps you took in order to enable this option? Also, is there any reason why you wanted the board to boot every 500ms?
Right now, let's try to reflash your board's BIOS and OS to see if that helps. Try to follow the steps in the following guides:
https://software.intel.com/en-us/flashing-the-bios-on-joule
https://software.intel.com/en-us/node/721486
Let us know if you have issues flashing the BIOS and the OS.
I hope this information helps you,
Pedro M.
Hello WeeHyong,
Do you have any updates about this?
Pedro M.
