Community
cancel
Showing results for
Search instead for
Did you mean:
AZhad
Intel Joule 570x BIOS update error
Hello! I`m trying to update BIOS on 570x to 1J2 (with 1H3 same problem):
Used stock USB cable.
flash.bat Joule_C0-X64-Release-1J2-Public_DNX.bin -clear
CMD:
Intel(R) Flash.bat version # 1.1.15
- Provisioning the eMMC...
- WARNING: Already provisioned!
- Checking for RPMB...
- Downloading the BIOS...
Flash log:
CLI version: 3.0.0.1081
Device serial:
Starting CONFIG DEVICE procedure
Device type: 0x2
Device index: 0
CONFIG DEVICE procedure failed
Error code: 0x80000036
Error message: Already configured
Starting READ BOOT MEDIA procedure
Device type: 0x2
Device index: 0
Start offset: 0
Blocks to read: 0x1000
Partition index: 0x10
READ BOOT MEDIA procedure failed
Error code: 0x80000031
Error message: RPMB not provisioned
Starting DOWNLOADFWOS procedure
DOWNLOADFWOS procedure success
So I`ve got no hdmi output and loop messade on serial:
MRC REVISION ID 1.52.29
MMRC REVISION ID 1.09
Really dont know what to do now
Community Manager
Hello xxl_cool,
Thank you for your interest in the Intel Joule 570x Compute Module.
Going on the details you sent us, could you please try to flash the board by using the -clear option.
Regarding the HDMI output you could try plugging in the monitor after booting or plugging/unplugging after booting.
Let me know if this helps and if I understood your issue correctly.
Casandra
AZhad
Hello, Casandra!
Thanks for Your answer,
I tried -clear option already without any effect.
About HDMI its not main problem, srangest things i see in serial output:
Looks like its in continuous reboot?
Community Manager
Hello xxl_cool,
It seems that the operating system on the Intel Joule Compute Module may be corrupted.
Could you please flash the board using the OS of your preference.
If you would like to get ref-os (stock image) the software can be downloaded here: https://download.01.org/ref-os-iot/releases/ https://download.01.org/ref-os-iot/releases/.
You can also find the guide on how to flash this image here https://software.intel.com/en-us/node/721472 https://software.intel.com/en-us/node/721472.
Let me know if this works.
Casandra
Community Manager
Hello xxl_cool,
Was the information provided previously useful?
Do you have any other questions related to this topic?
Casandra
AZhad
Thanks for info, Ill try next week, cant try now.
