Intel® Makers
9881 Discussions
Intel Joule;Ubuntu 16.04;mraa;SPI not working
ABhag
Platform
Board:Intel Joule 570X Expansion Board
OS:
uname -a
Linux scout-570x-DVT3 4.4.0-1000-joule # 0+joule12-Ubuntu SMP PREEMPT Fri Jan 6 04:28:41 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.1 LTS
Release: 16.04
Codename: xenial
MRAA
mraa-gpio version Version v1.7.0-11-g47c21e0 on INTEL JOULE EXPANSION
Program:Source
# include "mraa.h"
# include
# include
# include
int main(int argc, char** argv)
{ mraa_init();
//! [Interesting]
mraa_spi_context spi;
spi = mraa_spi_init(0);
printf("Hello, SPI initialised\n");
std::cout<<"spi init"< uint8_t data[] = { 0x00, 0x32 };</span>
uint8_t* recv;
std::cout<<"assigning data"< int i=90;</span>
data[1] = i;
std::cout<<"spi write coming up"< recv = mraa_spi_write_buf(spi, data, 2);</span>
if (recv==NULL)
std::cout<<"error in writing"< printf("Writing -%i\n", i);</span>
//printf("RECIVED-%i-%i\n", recv[0], recv[1]);
usleep(100000);
<span style="color: # 24292e; font-family: -apple-system, BlinkMacSystemFont, 'Segoe UI', Helvetica, Arial, sans-serif, 'Apple Color Emoji', 'Segoe UI Emoji', 'Segoe UI Symbo...
Community Manager
Hi Akshay,
Thanks for your interest in the Intel Joule platform.
Regarding that issue with the SPI, we have tested it using the Ref-OS-IoT image and we also have had issues with the SPI port, however, we'd like to let you know that currently we are working diligently in order to solve it, nevertheless, we do not have an ETA for this fix.
We understand you are using Ubuntu, but please keep in mind that we are now working on fixing this in the Ref-OS-IoT, these changes may or may not apply to other non-supported images.
Our apologies for the inconvenience it may cause.
-Yermi A.
FGold
New Contributor II
Akshay,
Have you tried spi-gpio-custom.c?
It is extremely slow, but at least appears to work.
bwang40
Hello!
I also use Ubuntu 16.04, but I cant include " # include "mraa.h" ", do I need download something or include other .hpp?
-noda
FGold
New Contributor II
Boda,
Have you installed mraa, and verified install?
https://github.com/intel-iot-devkit/mraa GitHub - intel-iot-devkit/mraa: Linux Library for low speed IO Communication in C with bindings for C++, Python, Node.js…
Installing on your boardhttps://github.com/intel-iot-devkit/mraa# installing-on-ubuntu https://github.com/intel-iot-devkit/mraa# installing-on-ubuntuInstalling on Ubuntu
Here is a PPA for installing on ubuntu: https://launchpad.net/~mraa/+archive/ubuntu/mraa https://launchpad.net/~mraa/+archive/ubuntu/mraa
sudo add-apt-repository ppa:mraa/mraa
sudo apt-get update
sudo apt-get install libmraa1 libmraa-dev mraa-tools python-mraa python3-mraa
Then verify:
- MRAA:
$ mraa-gpio version
Version v1.5.1 on Intel GT Tuchuck
