Intel® Makers
9882 Discussions
Intel Joule WIFI AP + hostapd issues
hgs
Hi all,
I am trying to bringup wifi AP 802.11n using hostapd on Intel Joule 570x module with OS 1706 release. Need few clarifications
1) Want to know if the hostapd.conf present in the release(OS 1706) has optimal settings?
2) hostapd binary which came with the release(OS 1706) was not built with CONFIG_ACS=y (auto channel selection).
I had to rebuild hostapd, but not sure about the .config option which I need to set apart from enabling CONFIG_ACS=y.
Additional information on steps to build the hostapd for intel joule platform will be really helpful.
3) we are trying to push this update to final product and would like to know about any stability issues other concerns related with
hostapd+802.11n AP setup.
Hari
Community Manager
Hello Hari,
Thank you for your patience.
Hostapd.conf has a variety of configurations that can be enabled to obtain desired settings for your preference. Using generic instructions to setup an access point on Linux for the Intel Joule should work. To connect to a Wi-Fi AP with the Intel Joule, or configure it manually, you can use the following guide: https://software.intel.com/en-us/node/721518 https://software.intel.com/en-us/node/721518
Hope this helps.
Octavian
Community Manager
Hello Hari,
Thank you for your interest in our Intel products.
We have taken your concern into review and will come back to you with more information in the shortest time possible.
Octavian
Community Manager
Hello Hari,
Hope this helps.
Octavian
hgs
Thanks for you reply.
Some background:
I use intel Joule 570x module with OS 1706 release. The intel joule is powered by baseboard powered battery which was charged continuously using 12 VDC external power supply as per spec.
I used hostapd to bringup WIFI AP on intel joule. Modified hostapd.conf (Attached hostapd.conf & hostapd.services) to enable 802.11n.
I saw a warning/crash after continuously running the system for 4 hours. Copy pasted the report captured from the console.
I also saw messages "Package temperature above threshold, cpu clock throttled"
Even though the system continued to work with out issues, i dont have clue about the the severity of this warning? Can you please explain the situation?
[16586.918238] ------------[ cut here ]------------
[16586.923431] WARNING: CPU: 1 PID: 623 at /var/lib/jenkins/jobs/release-builder-refos/workspace/build/tmp-glibc/work/intel_5xx_64-refos-linux/backport-iwlwifi/24-r0/git/drivers/net/wireless/intel/iwlwif]
[16586.948999] fc=0xa0[16586.951145] Modules linked in:
rfcomm intel_ipu4_isys_mod_bxtB0(O) videobuf2_v4l2 videobuf2_core intel_ipu4_psys_mod_bxtB0(O) intel_ipu4_mmu_bxtB0(O) intel_ipu4_mod_bxtB0(O) iova intel_ipu4_acpi(O) videobuf2_dma_contig videobuf2_memo)
[16587.077146] CPU: 1 PID: 623 Comm: hostapd Tainted: G O 4.9.27-intel-pk-standard # 1
[16587.086867] Hardware name: Intel Corp. 570x DVT3/SDS, BIOS GTPP1J2A.X64.0143.B30.1706270056 06/27/2017
[16587.097265] ffffc900025f3778 ffffffff813fc6da ffffc900025f37c8 0000000000000000
[16587.105546] ffffc900025f37b8 ffffffff8107bb3b 0000021000000000 ffff8801788fb700
[16587.113815] ffff8801788fb700 0000000000000018 ffff8801752eaf40 ffff880179639d48
[16587.122094] Call Trace:
[16587.124823] [] dump_stack+0x4d/0x63
[16587.130561] [] __warn+0xcb/0xf0
[16587.135911] [] warn_slowpath_fmt+0x4f/0x60
[16587.142339] [] iwl_mvm_tx_skb_non_sta+0x38c/0x4b0 [iwlmvm]
[16587.150320] [] iwl_mvm_mac_tx+0x110/0x1c0 [iwlmvm]
[16587.157527] [] ieee80211_tx_frags+0x13e/0x200 [mac80211]
[16587.165314] [] __ieee80211_tx+0x7e/0x180 [mac80211]
[16587.172618] [] ieee80211_tx+0xed/0x120 [mac80211]
[16587.179740] [] ieee80211_xmit+0x8b/0xb0 [mac80211]
[16587.186945] [] __ieee80211_tx_skb_tid_band+0x5c/0x70 [mac80211]
[16587.195411] [] ieee80211_mgmt_tx+0x42a/0x530 [mac80211]
[16587.203103] [] cfg80211_mlme_mgmt_tx+0xe0/0x300 [cfg80211]
[16587.211082] [] nl80211_tx_mgmt+0x213/0x350 [cfg80211]
[16587.218575] [] genl_family_rcv_msg+0x1b5/0x370
[16587.225380] [] ? poll_select_copy_remaining+0x120/0x120
[16587.233057] [] ? genl_family_rcv_msg+0x370/0x370
[16587.240057] [] genl_rcv_msg+0x86/0xc0
[16587.245985] [] netlink_rcv_skb+0xa4/0xc0
[16587.252204] [] genl_rcv+0x28/0x40
[16587.257747] [] netlink_unicast+0x184/0x220
[16587.264161] [] netlink_sendmsg+0x2c6/0x380
[16587.270577] [] ___sys_sendmsg+0x20e/0x270
[16587.276896] [] ? ___sys_recvmsg+0x14d/0x1c0
[16587.283411] [] ? pick_next_task_fair+0x36e/0x450
[16587.290412] [] ? ktime_get_ts64+0x4f/0x100
[16587.296825] [] __sys_sendmsg+0x45/0x80
[16587.302854] [] SyS_sendmsg+0x12/0x20
[16587.308689] [] entry_SYSCALL_64_fastpath+0x13/0x94
[16587.315904] ---[ end trace dcec104a67930c10 ]---
Hari
Community Manager
Hello Hari,
It's possible your CPU is overheating, we will investigate this issue and get back to you with more details.
Octavian
Community Manager
Hello Hari,
Are you using a cooling fan with your Intel Joule?
If not, please follow this guide to set up the stock cooling fan that comes in the Joule package: https://software.intel.com/en-us/node/733192
Hope this helps.
Octavian
