Community
cancel
Showing results for
Search instead for
Did you mean:
asing44
Intel MKL fatal error
I am trying to do face recognition with Intel edison.
The database I am using is AT&T. I have setup the environment and installed following libraries for doing the job using python:
python-numpy
python-scipy
python scikit-learn
This is the code that I have used.
from sklearn.decomposition import RandomizedPCA
import numpy as np
import glob
import cv2
import math
import os.path
import string
# function to get ID from filename
def ID_from_filename(filename):
part = filename.split('/')
return part[1].replace("s", "")
# function to convert image to right format
def prepare_image(filename):
img_color = cv2.imread(filename)
img_gray = cv2.cvtColor(img_color, cv2.COLOR_BGR2GRAY)
img_gray = cv2.equalizeHist(img_gray)
return img_gray.flat
IMG_RES = 92 * 112 # img resolution
NUM_EIGENFACES = 10 # images per train person
NUM_TRAINIMAGES = 410 # total images in training set
# loading training set from folder train_faces
folders = glob.glob('train_faces/*')
# Create an array with flattened images X
# and an array with ID of the people on each image y
X = np.zeros([NUM_TRAINIMAGES, IMG_RES], dtype='int8')
y = []
# Populate training array with flattened imags from subfolders of train_faces and names
c = 0
for x, folder in enumerate(folders):
train_faces = glob.glob(folder + '/*')
for i, face in enumerate(train_faces):
X[c,:] = prepare_image(face)
y.append(ID_from_filename(face))
c = c + 1
# perform principal component analysis on the images
pca = RandomizedPCA(n_components=NUM_EIGENFACES, whiten=True).fit(X)
X_pca = pca.transform(X)
# load test faces (usually one), located in folder test_faces
test_faces = glob.glob('test_faces/*')
X = np.zeros([len(test_faces), IMG_RES], dtype='int8')
# Populate test array with flattened imags from subfolders of train_faces
for i, face in enumerate(test_faces):
X[i,:] = prepare_image(face)
# run through test images (usually one)
for j, ref_pca in enumerate(pca.transform(X)):
distances = []
# Calculate euclidian distance from test image to each of the known images and save distances
for i, test_pca in enumerate(X_pca):
dist = math.sqrt(sum([diff**2 for diff in (ref_pca - test_pca)]))
distances.append((dist, y[i]))
found_ID = min(distances)[1]
print("Identified (result: "+ str(found_ID) +" - dist - " + str(min(distances)[0]) + ")")
When I run this code, I get the error,
Intel MTK fatal error unable to load libmkl_p4m3.so or libmkl_p4m4.so
Please help this project is very important for me.
Thanks in advance.
Tags (1)
Community Manager
Hello Arjun_289,
Could you explain to us how did you install MKL on your Edison? If I'm not mistaken the issue seems to be that a library from this package cannot be found by the code, this could mean that something might have gone wrong during the library's installation. Or some files are not stored in the correct location.
It would be of much help if you explain the steps you've taken so far (how you installed numpy, scipy, mkl, the dependencies, etc).
Peter.
asing44
Hi Peter,
Thanks for replying.
I have not installed MKL library myself. Since, I wanted to write a face recognition application in python,
I required the following libraries:
python-numpy
python -scipy
python-scikit-learn
python-opencv
In order to cater to this need, I installed miniconda and I installed theses libraries using conda.
One thing I would like to tell you is that I have two pythons of the same version running on edison. One is default and other has come with miniconda.
About the MKL error I haven't installed mkl libraries. I think they should be present by default with the image of yocto present on the board.
Please let me know if installing these can help me with this. I actually don't understand how the mkl libraries are used for performing maths functions, i am quite new to this thing.
Community Manager
The issue does seem to be that MKL is not installed in Edison, installing this library is likely to help you with the project. On a quick search I found https://software.intel.com/en-us/articles/intel-mkl-110-install-guide https://software.intel.com/en-us/articles/intel-mkl-110-install-guide. Why don't you check it and let us know if you are able to get MKL in your Edison.
Peter.
asing44
Thanks I'll try this out and let you know.
