Community
cancel
Showing results for
Search instead for
Did you mean:
AMath11
Intel Quark D1000 Error when programming with Eclipse on Win
I am trying to install the SDK for Quark D1000, but it always gives me a specific error:
1. On Linux: it says Path to 'iqdc' not found. (even though I have set the correct path to IQDC on eclipse, and system enivronment ).
it basically says '/tools/compiler/bin/iqdc' not found in PATH
2. On Windows, this error doesn't happen, and it worked fine the first time but now gives me the following error on openOCD:
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description '*' and serial '*'
Runtime Error: M:\intel\ISSM_d1000_2015.3.024\tools\debugger\openocd\scripts\aura_ftdi.cfg:15:
in procedure 'script'
at file "embedded:startup.tcl", line 58
in procedure 'init' called at file "M:\intel\ISSM_d1000_2015.3.024\tools\debugger\openocd\scripts\aura_ftdi.cfg", line 15
Any help would be appreciated.
Thank you
bartosz.firmwave
AdrianBurns
Hi Avijit,
Let see below workaround works or not;
1. On Linux, could you screen shot the error messages and project preferences setting for the iqdc in eclipse and system environment?
2. Could you check the Device Manager? It seem like no board detected by OpenOCD. This might be because of the driver installation.
AMath11
Hi Soffi,
Thanks for the reply, but it's sorted now.
1. On Linux it seems there was some problem with installing it in different directory than the original one
2. On Windows, re-installing the drivers fixed the problem.
Avijit
Hi Avijit,
Good to hear that.
For Linux, please ensure you run it on root (as SU) to ensure the ISSM work well.
