Intel® Makers
9874 Discussions
Intel Quark D2000: Storing Data in Flash
PPati4
Hello, I want to store data in Flash memory. Kindly let me know the procedure to store it.
Pedro_M_Intel
Hello Pratik_PP,
Have you checked the flash access example found in https://github.com/01org/qmsi/blob/master/examples/flash_access/main.c qmsi/main.c at master · 01org/qmsi · GitHub ? I believe it might be of much help to you.
Also, if you have System Studio installed on your computer you can go to the following path C:\IntelSWTools\ISSM_2016.0.027\firmware\bsp\1.0\doc\html and in there you will find a file called group__groupFlash.html, it will open a new browser window where you will be able to find more information about how to use the microcontroller's flash memory.
Peter.
Pedro_M_Intel
Hello Pratik_PP,
Peter.
