Community
cancel
Showing results for
Search instead for
Did you mean:
PPati4
Intel Quark D2000 wake-up problem
Jump to solution
Hello, I'm facing issues to wake up Intel Quark D2000 microcontroller from sleep mode(Sleep Mode with RTC). I have used the function soc_sleep() to put the controller to sleep and trying to wake it up using hardware interrupt i.e. switch present on the board. But the controller not waking up. Kindly let me know if I need to work on some additional settings for the interrupt to wake it up.
Diego_V_Intel
Hi Pratik_PP,
Before entering into a low power state, you have to configure the wake up source you are planning to use. This might be the reason why the microcontroller is not returning to the active state. I recommend you to check the datasheet on page 78 (section 9.2), that section explains the power down sequences: http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/d2000/quark-d2000-datasheet.html Intel® Quark™ Microcontroller D2000: Datasheet
In page 79 there is a summary of the settings you should do in order to configure a GPIO level triggered interrupt as wake up source.
Diego
Diego_V_Intel
Hi Pratik_PP,
Diego
