Community
cancel
Showing results for
Search instead for
Did you mean:
Michelle_C_Intel
Intel® Quark™ Microcontroller D2000 - How to flash the ROM from the Windows Command Line
Set Env -- c:\\IntelSWTools\\ISSM_2016.0.0XX\\issm_env.bat
cd %ISSM_DEBUGGER_ROOT%\openocd
bin\openocd.exe -f scripts\board\quark_d2000_onboard.cfg -c "flash_rom c:\\IntelSWTools\\ISSM_2016.0.0XX\\firmware\\bsp\\1.0\\soc\\quark_d2000\\rom\\quark_d2000_rom.bin 0"
Note : Replace XX with correct version number when running above commands. Output should be similar to that displayed below..
