Intel® Makers
9867 Discussions
Intel® Quark™ Microcontroller D2000 - Problem with new/fresh D2000 uC programming/update ROM
BZiol
Hi Intel,
I found a problem with each new (non-programmed) D2000 uC. After power-on I tried to update ROM first and I'm always receiving this error (using Intel System Studio 2016 for Microcontrollers):
"..Error: quark_d2000_flash_write: Bit ER_DONE in FLASH_STTS Timeout!"
Every time when I'm trying to update ROM (with newly soldered uC) I receive the same error.
To eliminate that (using default configuration in Intel System Studio - I don't know what is the proper one) I need to program first uC (some sample code). Then I'm receiving:
After that I'm able to update D2000 ROM:
After that I can program in normal way uC.
AdrianBurns
avijit.M
Michelle_C_Intel
Hi ,
Is the problem only seen in ISSM - or if you try to update the ROM using the command line do you see the same issue ?
regards,
Michelle.
BZiol
Hi Michelle,
The problem is with both with new soldered D2000 (never flashed before). Are there some special configurations/commands with flags/parameters to do that?
I wonder how to program D2000s in quick way in that case..
AdrianBurns
avijit.M
Bartosz
Michelle_C_Intel
Hi Bartosz,
In case there is some issue with the default configurations can you just loading the ROM image manually from the command line -- and let me know if you still see the issue.
Open Command Window :
cd IntelSWTools/ISSM_2016.0.0XX
issm_env.bat
cd %ISSM_DEBUGGER_ROOT%/openocd
bin\openocd -f scripts/board/quark_d2000_onboard.cfg
On a new window (or use a Terminal Emulator) open a telnet connection to OpenOCD :
telnet localhost 4444
clk32M
load_image ../../../firmware/bsp/1.0/soc/quark_d2000/rom/quark_d2000_rom.bin 0x0
regards,
Michelle.
BZiol
Hi Michelle,
I have still the same problem.
I've done what you wrote before with newly soldered D2000 (never flashed).
First, I've tried:
Open On-Chip Debugger
> clk32M
adapter speed: 3 kHz
redirect to PM, tapstatus=0x08302c14
unknown break reason at 0x0000ffff
target state: halted
target halted due to undefined at 0x0000ffff in real mode
adapter speed: 1000 kHz
JTAG tap: quark_d2000.cltap tap/device found: 0x0e786013 (mfg: 0x009, part: 0xe786, ver: 0x0)
Enabling lmt core tap
JTAG tap: quark_d2000.lmt enabled
target halted due to debug-request at 0x0000fff0 in real mode
The requested flash write overlaps the OTP DATA protected region 0x00000000 - 0x0000014f, skipping that part
The following command will allow it:
set QUARK_D2000_OTPC_DATA_WRITE_ENABLED 1
..quark_d2000_flash_write: Bit ER_DONE in FLASH_STTS Timeout!
in procedure 'load_image'
target running for unknown reason
Did you check it with never flashed uC?
Bartosz
AdrianBurns
avijit.M
PSuta
I had also same issue in using the second uart .....
You also try this solution
Short the GND and digital 0 pin. and restart the board . Don't forget to stop openocd. and start update ROM.
Community Manager
hi
someone get a solution for this?
i get the same that bartosz except at the end that i get
quark_d2000_flash_write: Write Flash Disabled
also tried with the digital pin 0 grounded, and happened the same
