Intel® Makers
9872 Discussions
Intel® Quark™ Microcontroller D2000 - Update Target ROM Fails : Could not update the ROM. Setup target failed
Community Manager
Community Manager
It looks that your board is connected to the host system, and the JTAG driver is installed properly. Yet the OpenOCD fails to communicate to the microcontroller. One possible reason is that the firmware on the microcontroller disabled the JTAG. For example JTAG might be disabled because firmware put the MCU into the sleep mode, or programmed pin multiplexers so that JTAG signals are no longer connected to the MCU pins. Try connecting a jumper wire between Arduino Header pin 0 (RX) and GND (e.g. pin next to the Arduino Header pin 13), resetting/reconnecting the board, and then re-flashing the board. Remove the jumper wire once board re-flashed successfully.
Community Manager
Thank you for your answer.
Still such a result.
Open On-Chip Debugger 0.8.0-dev-gba72ade-dirty (2016-07-19-11:13)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
trst_only separate trst_push_pull
(likely Digital Pin 0)
Info : clock speed 1000 kHz
Info : TAP quark_d2000.cltap does not have IDCODE
Warn : JTAG tap: quark_d2000.cltap UNEXPECTED: 0x00000000 (mfg: 0x000, part: 0x0000, ver: 0x0)
Error: JTAG tap: quark_d2000.cltap expected 1 of 1: 0x0e786013 (mfg: 0x009, part: 0xe786, ver: 0x0)
Warn : Unexpected idcode after end of chain: 1 0x80000000
Error: double-check your JTAG setup (interface, speed, missing TAPs, ...)
Error: Trying to use configured scan chain anyway...
Error: quark_d2000.cltap: IR capture error; saw 0xff not 0x1
Warn : Bypassing JTAG setup events due to errors
Setup clock
adapter speed: 3 kHz
Error: Target not examined yet
Runtime Error: c:/IntelSWTools/ISSM_2016.1.067/tools/debugger/openocd//scripts/target/quark_d2000.cfg:73:
in procedure 'flash_rom'
in procedure 'clk32M' called at file "c:/IntelSWTools/ISSM_2016.1.067/tools/debugger/openocd//scripts/target/quark_d2000.cfg", line 131
in procedure 'mww' called at file "c:/IntelSWTools/ISSM_2016.1.067/tools/debugger/openocd//scripts/target/quark_d2000.cfg", line 73
AZimi
New Contributor II
could you make a photo of your quark board?
Community Manager
AZimi
New Contributor II
Look at the picture bottom, you should place the jumper into red square pins
Community Manager
Jose_P_Intel
Hi lx,
Thanks for your interest in the Intel Quark Microcontrollers Platform.
This is a known issue, could please try the suggestions in the following threads:
I will be waiting for your reply, have a nice day.
-Jose.
Community Manager
Setup clock
