Community
cancel
Showing results for
Search instead for
Did you mean:
Michelle_C_Intel
Intel® Quark™ Microcontroller D2000 - Update Target ROM Fails : Could not update the ROM. Start process failed.
The Board is not connected or the driver is not installed.
Connect the Micro USB cable and verify 'OpenOCD JTAG' is connected via Device Manager.
Install/Re-install the driver if necessary using the 'install.bat' located in C:\IntelSWTools\ISSM_2016.0.0XX\tools\debugger\driver
