Community
cancel
Showing results for
Search instead for
Did you mean:
NHsie4
Intel® Quark™ SE MCU C1000 DFU over USB @ Windows*
I'm trying to implement the DFU over USB from QMSI Bootloader in Windows 8.1.
Hardware : MOUNT ATLAS FAB C (Intel® Quark™ SE Microcontroller C1000 Development Platform)
There is the software environment:
1
OS
Windows 8.1 64-bits
2
ISSM Version
ISSM_2016.2.090
3
MCU ROM Update
quark_se_rom_fm_2nd_stage.bin via ISSM 2016.2.090
Or
quark_se_rom_fm_2nd_stage.bin via Python (jflash.py –r)
4
second stage bootloader
2nd_stage_usb_hmac.bin via Python (jflash.py -u)
Or
2nd_stage_usb.bin via Python (jflash.py -u)
I following the "7.0 DFU over USB Guide " from Intel® QMSI Bootloader: User Guide (V2, Apr. 2017)
http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/se-soc/documentation.html http://www.intel.com/content/www/us/en/embedded/products/quark/mcu/se-soc/documentation.html
My Environment variables:
No.
Version
1
Set QM_BOOTLOADER_DIR=C:\IntelSWTools\...
Michelle_C_Intel
Hi NoSheng,
1. For quark_se the Authentication is done on the 2nd stage binary when you specify '2nd stage' as the Firmware Management type when building the ROM
Authentication is enabled by default so you can use 'make -C 2nd-stage' to build it with Authentication.
With Authentication enabled the 2 binaries will be : quark_se_rom_fm_2nd_stage.bin & 2nd_stage_usb_hmac.bin
Without Authentication enabled the 2 binaries will be : quark_se_rom_fm_2nd_stage.bin & 2nd_stage_usb.bin
2 / 3 . This is working fine for me both via command line and via IDE. As long as you can see ATP-Dev1.0 then you know that the 2nd stage bootloader is loaded ok. However you need to update the Driver to WinUSB. I used the 'Zadig' tool to do that.
4. The correct VID/PID is 8086:C1000 - I'll update the doc but as long as you have the '8086' part it should work fine.
The more likely issue is that the OS is not seeing it. This could be related to the driver issue above. Can you try 'dfu-util -l' to verify. You should see the output below if it is seeing it correctly.
c:\IntelSWTools\ISSM_2016.2.090\firmware\bsp\1.4.0\bootloader\tools\sysupdate>dfu-util -l
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/ http://sourceforge.net/p/dfu-util/tickets/
Found DFU: [8086:c100] ver=0100, devnum=11, cfg=1, intf=0, path="1-1", alt=2, name="Partition2 (ARC)", serial="00.01"
Found DFU: [8086:c100] ver=0100, devnum=11, cfg=1, intf=0, path="1-1", alt=1, name="Partition1 (LMT)", serial="00.01"
Found DFU: [8086:c100] ver=0100, devnum=11, cfg=1, intf=0, path="1-1", alt=0, name="QFM", serial="00.01"
5. I don't see the attachment ?
- Michelle.
NHsie4
Dear Michelle
The question 1~4 has be solved.
The question 4 Dowload & Free Run successfully, after used the 'Zadig' tool to update the Driver to WinUSB.
The question 4 log:
Opening DFU capable USB device...
ID 8086:c100
Run-time device DFU version 0101
Claiming USB DFU Interface...
Setting Alternate Setting # 1 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0101
Device returned transfer size 4096
Copying data from PC to DFU device
Download [=========================] 100% 4696 bytes
Download done.
state(2) = dfuIDLE, status(0) = No error condition is present
Done!
Resetting USB to switch back to runtime mode
make: Leaving directory `C:/IntelSWTools/ISSM_2016.2.090/workspace/.metadata/.plugins/com.intel.iss.mcu.bootloader/.workdir/firmware_qmsi/1.4.0/qmsi/examples/blinky'
The question 5 setting the authentication key :
Sorry about the missing attachment.
There are the commands I typed.
python .\tools\sysupdate\qm_manage.py set-rv-key C:\IntelSWTools\ISSM_2016.2.090\test20Apr -d 8086:c100
python .\tools\sysupdate\qm_manage.py set-rv-key test20Apr -d 8086:c100
python .\tools\sysupdate\qm_manage.py set-rv-key test20Apr --curr-rv-key test20Apr --curr-fw-key test20Apr -d 8086:c100
python .\tools\sysupdate\qm_manage.py set-fw-key test20Apr --curr-rv-key test20Apr -d 8086:c100
python .\tools\sysupdate\qm_manage.py set-fw-key test20Apr --curr-fw-key test20Apr --curr-rv-key test20Apr -d 8086:c100
Log of the question 5
Microsoft Windows [版本 6.3.9600]
(c) 2013 Microsoft Corporation. 著作權所有,並保留一切權利。
C:\Windows\system32>Set QM_BOOTLOADER_DIR=C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...
C:\Windows\system32>Set QMSI_SRC_DIR=C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...
C:\Windows\system32>Set TINYCRYPT_SRC_DIR=C:\IntelSWTools\ISSM_2016.2.090\tinycrypt
C:\Windows\system32>Set IAMCU_TOOLCHAIN_DIR=C:\IntelSWTools\ISSM_2016.2.090\tools\compiler\gcc-ia\5.2.1\bin
C:\Windows\system32>Set ARCMCU_TOOLCHAIN_DIR=C:\IntelSWTools\ISSM_2016.2.090\tools\compiler\gcc-arc\4.8.5\bin
C:\Windows\system32>cd C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...
C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...>python .\tools\sysupdate\qm_manage.py set-rv-key C:\IntelSWTools\ISSM_2016.2.090\test20Apr
-d 8086:c100
Programming new device key... Traceback (most recent call last):
File ".\tools\sysupdate\qm_manage.py", line 413, in
main()
File ".\tools\sysupdate\qm_manage.py", line 403, in main
manager.set_rv_key()
File ".\tools\sysupdate\qm_manage.py", line 348, in set_rv_key
self.set_key(qmfmlib.QFMRequest.REQ_SET_RV_KEY)
File ".\tools\sysupdate\qm_manage.py", line 324, in set_key
retv = self.call_tools(cmd + ["-D", file_name, "-a", "0"])
File ".\tools\sysupdate\qm_manage.py", line 129, in call_tools
stderr=subprocess.PIPE)
File "C:\Python27\lib\subprocess.py", line 672, in __init__
errread, errwrite)
File "C:\Python27\lib\subprocess.py", line 882, in _execute_child
startupinfo)
WindowsError: [Error 2] 系統找不到指定的檔案。
C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...>python .\tools\sysupdate\...
Michelle_C_Intel
Hi NoSheng,
Can you just confirm first the version of python you are using -- this looks like it may be a python issue. You need to use Version 2.7.10
c:\IntelSWTools\ISSM_2016.2.090>python --version
Python 2.7.10
There are 2 versions shipped with ISSM in the 'tools' dir so make sure the one in your PATH is 'c:/IntelSWTools/ISSM_2016.2.090/tools/python'
Directory of c:\IntelSWTools\ISSM_2016.2.090\tools
12/04/2017 10:45 .
12/04/2017 10:45 ..
12/04/2017 10:10 compiler
12/04/2017 10:21 compiler_llvm [C:\IntelSWTools\ISSM_2016.2.090\..\compilers_and_libraries_llvm_2016.0.024]
12/04/2017 10:10 debugger
12/04/2017 10:11 dfu_utils
12/04/2017 14:05 mingw
12/04/2017 10:21 python ----- Use this one .....2.7.10
12/04/2017 10:21 python3
20/04/2017 11:49 socwatch
12/04/2017 10:11 utils
- Michelle.
NHsie4
Dear Michelle :
PATH C:\Python27
The Python version in my command prompt:
(Python 2.7)
C:\Windows\System32>python --version
Python 2.7
There is the same error, after I change the PATH to 'C:\IntelSWTools\ISSM_2016.2.090\tools\python' and try again.
PATH C:\IntelSWTools\ISSM_2016.2.090\tools\python
(Python 2.7.10)
C:\Windows\system32>python --version
Python 2.7.10
C:\Windows\system32>Cd C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...
-d 8086:c100
main()
File "C:\IntelSWTools\ISSM_2016.2.090\tools\python\lib\subprocess.py", line 710, in __init__
errread, errwrite)
File "C:\IntelSWTools\ISSM_2016.2.090\tools\python\lib\subprocess.py", line 958, in _execute_child
startupinfo)
NoSheng.
Michelle_C_Intel
Ok - so it looks like it can't find the 'dfu-util' binary. I could replicate your error by removing it from my PATH
c:\IntelSWTools\ISSM_2016.2.090\firmware\bsp\1.4.0\bootloader>python .\tools\sysupdate\qm_manage.py set-rv-key C:\temp\rv-keyfile -d 8086
Programming new device key... [DONE]
c:\IntelSWTools\ISSM_2016.2.090\firmware\bsp\1.4.0\bootloader>python .\tools\sysupdate\qm_manage.py set-rv-key C:\temp\rv-keyfile -d 8086 -v
main()
File "c:\IntelSWTools\ISSM_2016.2.090\tools\python\lib\subprocess.py", line 710, in __init__
errread, errwrite)
File "c:\IntelSWTools\ISSM_2016.2.090\tools\python\lib\subprocess.py", line 958, in _execute_child
startupinfo)
WindowsError: [Error 2] The system cannot find the file specified
NHsie4
Dear Michelle :
There is no more Error, after I add the "dfu-util-0.9-win64" to the PATH. (C:\IntelSWTools\ISSM_2016.2.090\dfu-util-0.9-win64)
Log :
-d 8086:c100
Programming new device key... [FAIL]
key provisioning is not supported by the device.
I will keep going to set authentication key.
NoSheng.
Michelle_C_Intel
Hi NoSheng,
Just ensure that you have a ROM/2ndStageBinary loaded that supports Authentication - that error indicates that the Bootloader does not support Authentication.
e.g. quark_se_rom_fm_2nd_stage.bin & 2nd_stage_usb_hmac.bin
-- Michelle.
NHsie4
Dear Michelle :
Firmware Update successfully with Authentication Functionality in the Bootloader.
Thanks for your help,
NoSheng.
Create a secure DFU image:
C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...>python %QM_BOOTLOADER_DIR%\tools\sysupdate\qm_make_dfu.py --soc=quark_se -v examples\blinky\release\quark_se\x86\bin\blinky.bin --key C:\IntelSWTools\ISSM_2016.2.090\test20Apr -p 1
qm_make_dfu.py: QFU-Header content:
Partition: 1
VID: 0x0000
PID: 0x0000
DFU PID: 0x0000
Version: 0
Block Size: 4096
Blocks: 2
qm_make_dfu.py: examples\blinky\release\quark_se\x86\bin\blinky.bin.dfu written
Flash the secure image to the target:
C:\IntelSWTools\ISSM_2016.2.090\workspace\.metadata\.plugins\com.intel.iss.mcu.bootloader\.workdir\f...>dfu-util -D examples\blinky\release\quark_se\x86\bin\blinky.bin.dfu -d 8086:c100 -R -a 1
dfu-util 0.9
ID 8086:c100
dfuIDLE, continuing
Download done.
<p class="MsoNormal" style="mso-pa...
