Intel® Makers
9882 Discussions
Intel® Quark™ SE MCU C1000 USB CDC-ACM project
NHsie4
I'm trying to implement the project from QMSI 1.4.0 with MOUNT ATLAS FAB C (Intel® Quark™ SE Microcontroller C1000 Development Platform)
There is the software environment
1
OS
Windows 8.1 64-bits
2
ISSM Version
ISSM_2016.2.090
3
MCU ROM Update
For Intel® QMSI [1.4.0]
4
Project
USB_Communication_Device_Class__Abstract_Control_Model_
This app demonstrates the basic usage of the QMSI USB API through the implementation of a serial console over USB through the CDC-ACM Device Class
My Project running result as following:
MOUNT ATLAS FAB C
UART Console log
Starting: USB CDC ACM Example
CDC ACM Initialized. Waiting for DTR.
USB device supended
USB device reset detected
USB device connected
<p style="margin-t...
Michelle_C_Intel
Hi NoSheng,
If you are not seeing the device as a COM Port then most likely the issue is with the driver ... I used Zadig to ensure the 'USB Serial (CDC)' driver is used.
Expected Serial Output :
COM 4 - CDC-ACM
Send characters to the UART device.
Characters read:
COM 7 - UART
USB device supended
USB device configured
CDC_GET_LINE_CODING 115200 0 0 8
CDC_SET_CONTROL_LINE_STATE 0x0
CDC_SET_LINE_CODING 115200 0 0 8
CDC_SET_CONTROL_LINE_STATE 0x3
DCDC_SET_LINE_CODING 115200 0 0 8
TCDC_GET_LINE_CODING 115200 0 0 8
R CDC_GET_LINE_CODING 115200 0 0 8
sCDC_GET_LINE_CODING 115200 0 0 8
eCDC_GET_LINE_CODING 115200 0 0 8
tCDC_GET_LINE_CODING 115200 0 0 8
, CDC_SET_LINE_CODING 115200 0 0 8
tCDC_SET_CONTROL_LINE_STATE 0x3
arCDC_SET_LINE_CODING 115200 0 0 8
test.
Baudrate detected: 115200
USB CDC ACM set. Switch to the USB Serial Console.
CDC ACM IN BULK callback!
- Michelle.
Michelle_C_Intel
Hi NoSheng,
COM 4 - CDC-ACM
Characters read:
COM 7 - UART
USB device supended
test.
- Michelle.
NHsie4
Dear Michelle :
It is echo successfully from Terminal (COM port), after install 'USB Serial (CDC)' driver by Zadig tool.
Terminal (serial console) log:
Characters read:
Thanks!
