Community
cancel
Showing results for
Search instead for
Did you mean:
Michelle_C_Intel
Intel® Quark™ microcontroller D1000 - OpenOCD found a device, but lost it after disconnecting and reconnecting
Make sure that VCP (Virtual COM Port) is disabled for the USB Serial Converter B. When it is enabled,
Windows configures the second channel on FTDI as a serial port (second channel is used for JTAG). This
prevents firmware from starting after the board is connected to USB. Follow the instructions below and
be sure to reboot. The change takes effect only after a reboot.
