Intel® Makers
9881 Discussions
Intel® Quark™ microcontroller D1000 - PuTTY doesn't find any COM ports
Michelle_C_Intel
You need to (re)install an FTDI serial port driver. Go to http://www.ftdichip.com/Drivers/D2XX.htm http://www.ftdichip.com/Drivers/D2XX.htm and install the appropriate driver. When drivers are correctly installed,
The device manger should show (at least) one COM port and one Dual RS232-HS USB device.
