Intel® Makers
9881 Discussions
Intel(R) Ref-OS-IoT Build failed
Community Manager
I'm trying to build the Ref-OS-IoT. It's project requirement to replace exiting kernel with custom kernel.
Followed Link: https://github.com/01org/ref-os-iot GitHub - 01org/ref-os-iot: This is the official distribution of the Intel(R) Reference Operating System for the Internet…
Following error occurs while building meta-clang
DEBUG: Executing python function sysroot_cleansstate
DEBUG: Python function sysroot_cleansstate finished
DEBUG: Executing shell function do_configure
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Found assembler: x86_64-refos-linux-gcc
CMake Error at CMakeLists.txt:54 (project):
The CMAKE_C_COMPILER:
is not a full path and was not found in the PATH.
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
The CMAKE_CXX_COMPILER:
x86_64-refos-linux-g++
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
The CMAKE_ASM_COMPILER:
variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
cmake looking for x86_64-refos-linux-gcc, x86_64-refos-linux-g++, etc. Could you please let me know where can i find the above cross compiler?
Vishnu
Community Manager
Hello Vishnu,
Thanks for reaching out!
I'm current building Joule's ref-os-iot on my Ubuntu 16.04 virtual machine in order to see if I can replicate the issue you are experiencing. I'll let you know as soon as I have any updates.
Pedro M.
Community Manager
Hello Vishnu,
I left my laptop (with a virtual machine) running over the weekend in order to update you today. Nevertheless, it seems I have an issue with my laptop's charger as even though it was connected, it did not charge. So, when I checked the laptop again today I found that it was off and the battery drained. So, the image never finished building.
I'm currently building the image again, I made sure the laptop is now charging and should finish the process soon. I will get back to you once it finishes or if I'm able to see the same behavior as you.
Peter.
Community Manager
I've finally been able to finish building the Ref-OS-IoT image. The only issues I had were internet-related, I lost connection a couple of times but after resetting the build, the process would continue. Unfortunately, I was not able to replicate the issue you are facing. These are the steps I followed:
sudo apt update
sudo apt-get install gawk wget git-core git diffstat unzip texinfo gcc-multilib build-essential chrpath socat libsdl1.2-dev xterm subversion xsltproc
mkdir -p $HOME/work
cd $HOME/work
git clone https://github.com/01org/ref-os-iot
cd ref-os-iot
git submodule update --recursive --init
source 5xx-init-build-env
bitbake full-image
These steps worked with no issues on my Ubuntu 16.04 Virtual Machine.
Pedro M.
MEdwa4
I am also seeing the same issue trying to execute a bitbake full-image -c populate_sdk command for the intel Joule platform, running on an Ubuntu 16.04 host platform. Debug output attached below. Any other ideas on what I could be doing wrong?
Mark Edwards
Log data follows:
| -- Found assembler: x86_64-refossdk-linux-gcc
| x86_64-refossdk-linux-g++
| -- Warning: Did not find file Compiler/-ASM
| -- Configuring incomplete, errors occurred!
| See also "/home/mark/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/build/CMakeFiles/CMakeOutput.log".
| See also "/home/mark/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/build/CMakeFiles/CMakeError.log".
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_configure (log file is located at /home/mark/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/temp/log.do_configure.26763)
Community Manager
Hi eeynmre,
I just started the image building process again but this time with the command bitbake full-image -c populate_sdk, let me see if I can replicate the behavior you are describing.
I will update you once the building finishes.
Pedro M.
MEdwa4
Hi Pedro,
do you have any update on my and Vishnu's issue? I am still stalled on it and would like to get moving again!
Mark Edwards
Community Manager
Sorry for the delay in my response. Yes, I do have an update for this. I've been running some tests, trying to build the image with the additional "-c populate_sdk", yet I have not been able to do so. This is my output:
makers@makers-VirtualBox:~/Documents/Peter/work/ref-os-iot/build$ bitbake full-image -c populate_sdk
Loading cache: 100% |# | Time: 0:00:02
Loaded 3355 entries from dependency cache.
Parsing recipes: 100% |# | Time: 0:00:02
Parsing of 2547 .bb files complete (2543 cached, 4 parsed). 3359 targets, 145 skipped, 0 masked, 0 errors.
WARNING: No bb files matched BBFILE_PATTERN_batman '^/home/makers/Documents/Peter/work/ref-os-iot/build/../meta-ref-os-iot/meta-common/meta-batman/'
WARNING: No bb files matched BBFILE_PATTERN_intel-arduino '^/home/makers/Documents/Peter/work/ref-os-iot/build/../meta-ref-os-iot/meta-common/meta-intel-arduino/'
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.33.1"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "x86_64-refos-linux"
MACHINE = "intel-5xx-64"
DISTRO = "ref-os-iot"
DISTRO_VERSION = "1.0+snapshot-20170508"
TUNE_FEATURES = "m64 corei7"
TARGET_FPU = ""
meta
meta-selftest = "HEAD:9f225ef5620f2e47e762b2fd16fa5f8d6f1f60fd"
meta-intel = "HEAD:5153dad2fa695bbb579c03ff795ef649269e8420"
meta-refkit = "HEAD:11c3a736d9e824c85f50653db3ec5adabe47a8ae"
meta-oic = "HEAD:b9ba736871b8f8b741cc9c1d88dda56e63a35091"
meta-iot-web = "HEAD:7960e39f92434ee968fc86e38a98eeffdc5041fa"
meta-gnome
meta-networking
meta-oe
meta-python
meta-xfce = "HEAD:5ecbf9bab404af0de7d0f058d1620f40dae0d2d8"
meta-intel-realsense = "HEAD:d60a3c69e0a9f38bdead72bc39857d891f32585c"
meta-ref-os-iot = "master:c320ccd962953eee52be7584167f10a99ac308ca"
meta-qt5 = "HEAD:81fb771c3f31110e50eebcb004809361fdb28194"
meta-ros = "HEAD:2cd378a1c1702e7b3e4ef3e97e987eb6af7b56e0"
meta-java = "HEAD:a265b31ec7d022be254abdf959360a7624208585"
meta-clang = "HEAD:dc1d9d550a5d33d76a3bc6162739edccbd8bf012"
meta-batman = "HEAD:925ad8343613ca3c4274840b9e18225f5be0d231"
meta-intel-camera = "HEAD:a8c6730c2ca7608646a00b7da5460cbc6a08d902"
meta-intel-arduino
meta-5xx = "master:c320ccd962953eee52be7584167f10a99ac308ca"
Initialising tasks: 100% |# | Time: 0:00:23
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: nativesdk-clang-3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0 do_configure: Function failed: do_configure (log file is located at /home/makers/Documents/Peter/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/temp/log.do_configure.2555)
ERROR: Logfile of failure stored in: /home/makers/Documents/Peter/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/temp/log.do_configure.2555
Log data follows:
| See also "/home/makers/Documents/Peter/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/build/CMakeFiles/CMakeOutput.log".
| See also "/home/makers/Documents/Peter/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/build/CMakeFiles/CMakeError.log".
| ERROR: Function failed: do_configure (log file is located at /home/makers/Documents/Peter/work/ref-os-iot/build/tmp-glibc/work/x86_64-nativesdk-refossdk-linux/nativesdk-clang/3.8.0+gitAUTOINC+06cf4b238f_9fd77bd681-r0/temp/log.do_configure.2555)
ERROR: T...
MEdwa4
Hi Pedro,
do you have any further updates on this matter, I am still stalled because of it and REALLY need to get moving again. Can I supply you with any further information from my build to assist you in your investigations?
Best Regards
Mark Edwards
Community Manager
Hello Mark,
Unfortunately no, we don't have any updates at this point. We are currently working on this, in fact we have informed the engineering team about this so they can also take a look at it.
We appreciate your patience and we apologize for any inconvenience or delay that this might be causing. We will reply to this thread as soon as we have any news.
Pedro M.
Community Manager
Hello Mark,
We have an update for this case.
A fix for this issue has been pushed to the Ref-OS-IoT GitHub for SDK. It is now available at:
https://github.com/01org/ref-os-iot/commit/1d2a875aafaf3492d3971c459b7fe5b5cf796314
Please add this fix to your build, try again and let us know how it goes.
Pedro M.
