Community
cancel
Showing results for
Search instead for
Did you mean:
PDani3
Intel XDK IOT connError
Jump to solution
I am trying to connect galileo to a wifi in intel xdk iot and its giving me this error on the console: Error /net/connman/service/wifi_0cd29296cf17_4353435f484f44_managed_none: Input/output error. It's strange, I mean i have been connecting to galileo previously without problems. At other times it gives me: "Agent Report Error: wifi_0cd29296cf17_4353435f484f44_managed_none".
Somebody please help me.
Sergio_A_Intel
What XDK version are you using, the latest version is 2571. Can you confirm that you have configured an IP address in your Galileo? From the terminal, type ifconfig to see the IP address of wlan0. Once this is completed, connect manually using the "Add Manual Connection" option. Make sure to enter the correct User Name and Password.
If you are experiencing issues connecting to your board, connect to your board in a serial communication session and type the following:
systemctl enable xdk-daemon
systemctl restart xdk-daemon
Sergio
ASouz7
PETRONG,
We have moved your thread to the forum in order for you to obtain proper answer.
Sergio_A_Intel
Sergio
PDani3
Thanks a lot
