Intel® Makers
9874 Discussions
Intel XDK Upload to Edison Arduino Board
SAlbr
I recently bought an Intel Edison AWS IoT starter kit and am trying to run one of the example files on GitHub:
https://github.com/intel-iot-devkit/aws-iot-intel/tree/master/Javascript aws-iot-intel/Javascript at master · intel-iot-devkit/aws-iot-intel · GitHub
I made the modifications to the JS file as suggested and uploaded to the Edison board through XDK IDE. However, I cannot find the uploaded file. What directory is the file uploaded to and which directory should it be executed from?
Steve Albright
MQuin12
Hello @steve_albright
You can build IoT Solutions with https://goo.gl/ABiJBj AWS and Intel.
AWS IOT is a new service that supports secure bi-directional communication between Internet-connected things and the AWS cloud. An expansive variety of IoT solutions are possible when combining AWS and Intel technologies, including crowd management, temperature monitoring, air pollution, and agricultural solutions.
The IoT Demo Lab at the London AWS Loft gave UK startups the opportunity to understand how AWS and Intel can help shape their current and future IoT applications.
SAlbr
This is the kit that I purchased. It is AWS / Intel / Grove:
https://www.amazon.com/Intel%C2%AE-Edison-Grove-Starter-Powered/dp/B0168KU5FK Amazon.com: Intel® Edison and Grove IoT Starter Kit Powered by AWS: Computers & Accessories
But I still dont know, if I upload a file from XDK IDE to the Edison board, what directory does the file upload to? And for the example mentioned above, what directory should I be running the Javascript file in?
Steve
Community Manager
Hello Steve,
Thanks for reaching out.
There are two ways to run the application, you could run it directly from Intel XDK, check the following picture:
If you need to run the application inside the Edison, the code is located in the ~/.node_app_slot directory, you can execute the code there using the following command: node main.js
I hope you find this useful, let us know if it works.
Have a nice day.
Leonardo R.
Community Manager
Hello Steve,
Do you have any updates?
We will be waiting for your reply.
Leonardo R.
SAlbr
Hi Leonardo,
I am working through another issue related to WiFi connectivity on another support case, before I can troubleshoot this issue any further.
Steve
Community Manager
Hello Steve,
Thank you for letting us know. We will wait for your results.
Have a nice day.
Leonardo R.
