Community
cancel
Showing results for
Search instead for
Did you mean:
dvian
Intel XDK
hello everybody,
I return again this week because now my card captures the wifi but for me it impossible to run a project with Intel xdk you and I make a copy of what he said:
q@1.4.1 ..\..\..\Users\viann\Documents\lcd\node_modules\qtransferring C:\Users\viann\AppData\Local\Temp\xdk-93363d8jc0g.tar from project to board
x lcd.js
x main.js
x package.json
x README.md
x xdk/project-info.json
transferring C:\Users\viann\AppData\Local\Temp\xdk-9336aod2zio.tar from project to board
x q/CHANGES.md
x q/LICENSE
x q/package.json
x q/q.js
x q/queue.js
x q/README.md
q@1.4.1 /home/root/.node_app_slot/node_modules/q
build complete
Upload Complete
Not auto starting by request
UPLOADING: Uploading project bundle to IoT device.
[ Upload Complete ]ERROR: module.js:355
Module._extensions[extension](this, filename);
Error: Module did not self-register.
at Error (native)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Module.require (module.js:365:17)
at require (module.js:384:17)
at Object. (/home/root/.node_app_slot/main.js:21:12)
at Module._compile (module.js:460:26)
at Object.Module._extensions..js (module.js:478:10)
at Module.load (module.js:355:3...
Carlos_M_Intel
Hi vianney,
Are you using the XDK IDE 2571?
Which image are you using?
Could you attach the code you are using?
Are you able to run the blink example on the XDK?
Charlie
dvian
hey Charlie,
I use version 2571 intel xdk
the image is the last that is to say 2.1
Here is the code to blink :
/*jslint node:true, vars:true, bitwise:true, unparam:true */
/*jshint unused:true */
A simple node.js application intended to blink the onboard LED on the Intel based development boards such as the Intel(R) Galileo and Edison with Arduino breakout board.
MRAA - Low Level Skeleton Library for Communication on GNU/Linux platforms
Library in C/C++ to interface with Galileo & other Intel platforms, in a structured and sane API with port nanmes/numbering that match boards & with bindings to javascript & python.
Steps for installing MRAA & UPM Library on Intel IoT Platform with IoTDevKit Linux* image
Using a ssh client:
1. echo "src maa-upm http://iotdk.intel.com/repos/1.1/intelgalactic http://iotdk.intel.com/repos/1.1/intelgalactic" > /etc/opkg/intel-iotdk.conf
2. opkg update
3. opkg upgrade
Article: https://software.intel.com/en-us/html5/articles/intel-xdk-iot-edition-nodejs-templates https://software.intel.com/en-us/html5/articles/intel-xdk-iot-edition-nodejs-templates
var mraa = require('mraa'); //require mraa
console.log('MRAA Version: ' + mraa.getVersion()); //write the mraa version to the Intel XDK console
//var myOnboardLed = new mraa.Gpio(3, false, true); //LED hooked up to digital pin (or built in pin on Galileo Gen1)
var myOnboardLed = new mraa.Gpio(13); //LED hooked up to digital pin 13 (or built in pin on Intel Galileo Gen2 as well as Intel Edison)
myOnboardLed.dir(mraa.DIR_OUT); //set the gpio direction to output
var ledState = true; //Boolean to hold the state of Led
periodicActivity(); //call the periodicActivity function
function periodicActivity()
myOnboardLed.write(ledState?1:0); //if ledState is true then write a '1' (high) otherwise write a '0' (low)
ledState = !ledState; //invert the ledState
setTimeout(periodicActivity,1000); //call the indicated function after 1 second (1000 milliseconds)
Here is the error message after you try to deploy blink :
Intel XDK - IoT App Daemon v0.0.37 - commands: run, list, debug, status
Upload on board is not from current project - uploading complete project
No NPM modules found.
transferring C:\Users\viann\AppData\Local\Temp\xdk-117602nvyz00.tar from project to board
x main.js
x package.json
x README.md
Upload Complete
and there is also that before he told me all the time meter of the date and time a day <spa...
dvian
Here is more information in order to try and resolve my concern continuing to search I try to do the project blink on another computer with the Intel version of xdk 2170 the project here:
Using a ssh client:
2. opkg update
3. opkg upgrade
the project still does not want to start, here is the error message:
New System Time: Thu Jan 14 2016 00:41:46 GMT+0000 (UTC)
[ Upload Complete ]
| Intel (R) IoT - NPM Install - (may take several minutes)
npm WARN package.json OnboardLEDBlink@0.0.0 No repository field.
| NPM INSTALL COMPLETE![ 0 ] [ 0 ]
[ Upload Complete ]
[ Upload Complete ]npm WARN package.json OnboardLEDBlink@0.0.0 No repository field.
ERROR: module.js:355 ...
Carlos_M_Intel
Hi vianney,
I suggest you to use the 2571 XDK version.
After running configure_edison --version you should have as result 159 or 159.devkit
The /etc/opkg/iotkit.conf file should have the following content:
src iotkit http://iotdk.intel.com/repos/2.0/intelgalactic http://iotdk.intel.com/repos/2.0/intelgalactic
src iotdk-all http://iotdk.intel.com/repos/2.0/iotdk/all http://iotdk.intel.com/repos/2.0/iotdk/all
src iotdk-i586 http://iotdk.intel.com/repos/2.0/iotdk/core2-32 http://iotdk.intel.com/repos/2.0/iotdk/core2-32
src iotdk-quark http://iotdk.intel.com/repos/2.0/iotdk/core2-32-intel-common http://iotdk.intel.com/repos/2.0/iotdk/core2-32-intel-common
src iotdk-x86 http://iotdk.intel.com/repos/2.0/iotdk/intel_core2_32 http://iotdk.intel.com/repos/2.0/iotdk/intel_core2_32
The /etc/opkg/base-feeds.conf file should be empty or with:
src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
Then run the commands:
opkg update
opkg install mraa
opkg install upm
This will install the latest version of these libraries and you should have been able to run the code with the XDK.
Try also with selecting the options:
Manage your daemon/IoT application > Sync time w/clock on target device
Manage your daemon/IoT application > Update Libraries on board
Charlie
Carlos_M_Intel
Hi vianney,
Do you have updates on this? Have you been able to use the XDK?
Charlie
dvian
hey,
I'm sorry, I had not seen the previous answer ...
alor here's what I did:
Poky (Yocto Project Reference Distro) 1.7.2 vianney ttyMFD2
vianney login: root
Password:
root@vianney:~# configure_edison--version
-sh: configure_edison--version: command not found
root@vianney:~# configure_edison --version
159.devkit
root@vianney:~# /etc/opkg/iotkit.conf
-sh: /etc/opkg/iotkit.conf: Permission denied
root@vianney:~# /etc/opkg/base-feeds.conf
-sh: /etc/opkg/base-feeds.conf: Permission denied
root@vianney:~# sudo /etc/opkg/base-feeds.conf
-sh: sudo: command not found
root@vianney:~#
permission denied what?
Vianney
dvian
hey,
I just start eg temperature, I plug the temperature sensor on A0, and run the program:
/*jslint node:true,vars:true,bitwise:true,unparam:true */
The Local Temperature Node.js sample application distributed within Intel® XDK IoT Edition under the IoT with Node.js Projects project creation option showcases how to read analog data from a Grover Starter Kit Plus – IoT Intel® Edition Temperature Sensor, start a web server and communicate wirelessly using WebSockets.
Using a ssh client:
2. opkg update
3. opkg upgrade
Article: https://software.intel.com/en-us/html5/articles/iot-local-temperature-nodejs-and-html5-samples https://software.intel.com/en-us/html5/articles/iot-local-temperature-nodejs-and-html5-samples
var B = 3975;
var mraa = require("mraa");
//GROVE Kit A0 Connector --> Aio(0)
var myAnalogPin = new mraa.Aio(0);
Function: startSensorWatch(socket)
Parameters: socket - client communication channel
Description: Read Temperature Sensor and send temperature in degrees of Fahrenheit every 4 seconds
function startSensorWatch(socket) {
'use strict';
setInterval(function () {
var a = myAnalogPin.read();
console.log("Analog Pin (A0) Output: " + a);
//console.log("Checking....");
var resistance = (1023 - a) * 10000 / a; //get the resistance of the sensor;
//console.log("Resistance: "+resistance);
var celsius_temperature = 1 / (Math.log(resistance / 10000) / B + 1 / 298.15) - 273.15;//convert to temperature via datasheet ;
//console.log("Celsius Temperature "+celsius_temperature);
var fahrenheit_temperature = (celsius_temperature * (9 / 5)) + 32;
console.log("Fahrenheit Temperature: " + fahrenheit_temperature);
socket.emit("message", fahrenheit_temperature);
}, 4000);
console.log("Sample Reading Grove Kit Temperature Sensor");
//Create Socket.io server
var http = require('http');
var app = http.createServer(function (req, res) {
'use strict';
res.writeHead(200, {'Content-Type': 'text/plain'});
res.end('Hello world from Intel IoT platform!');
}).listen(1337);
var io = require('socket.io')(app);
//Attach a 'connection' event handler to the server
io.on('connection', function (socket) {
'use strict';
console.log('a user connected');
//Emits an event along with a message
socket.emit('connected', 'Welcome');
//Start watching Sensors connected to Galileo board
startSensorWatch(socket);
//Attach a 'disconnect' event handler to the socket
socket.on('disconnect', function () {
console.log('user disconnected');
but here is what I:
socket.io@1.4.4 ..\..\..\Users\viann\Documents\temprature\node_modules\socket.io
├── has-binary@0.1.7 (isarray@0.0.1)
├── debug@2.2.0 (ms@0.7.1)
├── socket.io-parser@2.2.6 (isarray@0.0.1, component-emitter@1.1.2, json3@3.3.2, benchmark@1.0.0)
├── engine.io@1.6.7 (base64id@0.1.0, ws@1.0.1, engine.io-parser@1.2.4, accepts@1.1.4)
├── socket.io-adapter@0.4.0 (socket.io-parser@2.2.2)
└── socket.io-client@1.4.4 (indexof@0.0.1, to-array@0.1.3, component-emitter@1.2.0, backo2@1.0.2, object-component@0.0.3, component-bind@1.0.0, parseuri@0.0.4, socket.io-parser@2.2.5, engine.io-client@1.6.7)transferri
ng C:\Users\viann\AppData\Local\Temp\xdk-588419je0s0.tar from project to board
x main.js
x package.json
x README....
dvian
Now if I make a test with blink:
Using a ssh client:
2. opkg update
3. opkg upgrade
the whole is good and its progress :
transferring C:\Users\viann\AppData\Local\Temp\xdk-4848e9tttls.tar from project to board
x main.js
x package.json
x README.md
Upload Complete
Carlos_M_Intel
Hi vianney,
In order to check the content of the file you have to run the commands cat /etc/opkg/base-feeds.conf and cat /etc/opkg/iotkit.conf. Remember that you don't have and don't need sudo because you are already logged as the root user.
I'm guessing you are using the Local Temperature example on the XDK, this example allows you to create a webserver and send data through WebSockets, for more information about this example check the README.md file on the project.
If you want to see the data from the sensor on the console of the XDK IDE, take out the code from the function startSensorWatch(), you can use the following code:
var B = 3975;
Charlie
dvian
hey charlie,
Thank you for the answer, so I just did the tests, here is what happens:
vianney login: root
Password:
root@vianney:~# cat /etc/opkg/base-feeds.conf
src/gz all http://repo.opkg.net/edison/repo/all/ http://repo.opkg.net/edison/repo/all/
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/
src/gz edison http://repo.opkg.net/edison/repo/edison/ http://repo.opkg.net/edison/repo/edison/
root@vianney:~# cat /etc/opkg/iotkit.conf
root@vianney:
I think he lacks, how to install?
Vianney
Carlos_M_Intel
Hi vianney,
Did the code work for you?
Regarding the content on the .conf files, you shouldn't be worry about this unless you want to install a package from that repository. You already have the 0.9.0 MRAA version so you don't need to update it.
If you want to update the conf file you can copy and paste the following content in the iotkit.conf by using vi.
Charlie
dvian
hi charlie,
I just execute the code:
var B = 3975;
and it works
transferring C:\Users\viann\AppData\Local\Temp\xdk-12652v06jkkg.tar from project to board
x main.js
x package.json
x README.md
Upload Complete
Analog Pin (A0) Output: 379
Fahrenheit Temperature: 56.47521534482727
Analog Pin (A0) Output: 481
Fahrenheit Temperature: 72.23642911081114
<p style="font-family: Menlo, 'De...
