Hi,I want to use ili9341 lcd in Intel Xdk Iot Ide.Do you know library for ili9341 in Intel Xdk Iot Ide.
Hi ErayAktokluk,
I'm not aware if there's an available library for the XDK. But there's one for Arduino developed by another user, you can find it here https://github.com/KurtE/Adafruit_ILI9341/tree/Intel-Edison https://github.com/KurtE/Adafruit_ILI9341/tree/Intel-Edison. You can use the one from the link, but if you need to use the XDK you can edit the Arduino library to fit your needs. It will require some more work, though. Is it mandatory for you to use the Intel XDK?
After some more research, the same user was also working some examples on Edison using MRAA, https://github.com/KurtE/Raspberry_Pi/tree/master/Adafruit_ILI9341C this might be of help.
PabloM_Intel
Hi ErayAktokluk,
PabloM_Intel
