Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel edison Problems uploading sketch
This is the error message that i got in my IDE.
Build options changed, rebuilding all
Sketch uses 81,113 bytes (0%) of program storage space. Maximum is 10,000,000 bytes.
# !/bin/sh
starting download script
# clupload script to invoke lsz
# Copyright (C) 2014 Intel Corporation
Args to shell: C:\Users\jonathanrjpereira\AppData\Roaming\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\JONATH~1\AppData\Local\Temp\build5302849050521660872.tmp/SimplePost.cpp.elf COM4
COM PORT 4
# This library is free software; you can redistribute it and/or
Converted COM Port COM4 to tty port /dev/ttyS3
# modify it under the terms of the GNU Lesser General Public
Sending Command String to move to download if not already in download mode
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
# path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
# COM ports are not always setup to be addressed via COM for redirect.
# /dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadEdison" > $tty_port_id
Deleting existing sketch on target
# Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
Transfer complete
# Execute the target download command
# Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
2 [main] bash 3352 child_info_fork::abort: C:\Users\jonathanrjpereira\AppData\Roaming\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0\x...: Loaded to different address: parent(0x4D0000) != child(0x5D0000)
C:\Users\jonathanrjpereira\AppData\Roaming\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.s...
Highlighted
Hello jonathanrjpereira,
Are you selecting the correct COM port and the correct board in the Arduino IDE? Is this the first time you try to upload a sketch?
I prefer to use the Arduino IDE 1.6.0 which already includes the Edison and Galileo packages. I suggest you to try to upload a sketch with this IDE version and check if you get the same error message. The Arduino IDE 1.6.0 can be downloaded from here: http://downloadmirror.intel.com/24783/eng/IntelArduino-1.6.0-Windows.7z Arduino IDE 1.6.0.
Diego.
