Intel® Makers
9872 Discussions
Intel edison bootup problem
BRAME
Hi!
I am facing problem while working with Intel Edison.
It was booted up well till yesterday but after upgrading it is not booting up properly.
Please help me for the following error
U-Boot 2014.04 (Apr 29 2015 - 04:05:44)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
Flashing already done...
GADGET DRIVER: usb_dnl_dfu
reading vmlinuz
5338304 bytes read in 133 ms (38.3 MiB/s)
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.17-yocto-standard (sys_dswci@tlsndgbuild004) # 1 SMP PREEMPT Wed Apr 29 04:08:25 CEST 2015
Building boot_params at 0x00090000
Loading bzImage at address 00100000 (5322944 bytes)
Kernel command line: "rootwait root=PARTUUID=012b3303-34ac-284d-99b4-34e03a2335f4 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep loglevel=4 g_multi.ethernet_config=rndis systemd.unit=multi-user.target hardware_id=00 g_multi.iSerialNumber=d16235eb2845afb010c08be983de6ae3 g_multi.dev_addr=02:00:86:de:6a:e3 platform_mrfld_audio.audio_codec=dummy"
Starting kernel ...
[ 1.653757] snd_soc_sst_platform: Enter:sst_soc_probe
[ 2.007537] pmic_ccsm pmic_ccsm: Error reading battery profile from battid frmwrk
[ 2.015949] pmic_ccsm pmic_ccsm: Battery Over heat exception
Welcome to Linux!
Expecting device dev-ttyMFD2.device...
[ OK ] Reached target Remote File Systems.
Expecting device sys-subsystem-net-devices-wlan0.device...
Expecting device dev-disk-by\x2dpartlabel-factory.device...
Expecting device sys-subsystem-net-devices-usb0.device...
[ OK ] Reached target Paths.
[ OK ] Set up automount Arbitrary Executable File Formats F...utomount Point.
[ OK ] Reached target Swap.
[ OK ] Set up automount boot.automount.
[ OK ] Created slice Root Slice.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice User and Session Slice.
[ OK ] Created slice System Slice.
Mounting POSIX Message Queue File System...
Mounting Debug File System...
Starting Journal Service...
[ OK ] Started Journal Service.
Starting Create list of required static device nodes...rrent kernel...
Starting Apply Kernel Variables...
Starting udev Coldplug all Devices...
Starting Load Kernel Modules...
[ OK ] Reached target Slices.
Starting Remount Root and Kernel File Systems...
[ OK ] Created slice system-serial\x2dgetty.slice.
