Community
cancel
Showing results for
Search instead for
Did you mean:
KNaga15
Intel edison gets stuck and loops at booting
Jump to solution
Hi, I have been getting trouble at booting my edison.
So I stopped the autoboot and did:
> run do_flash
But I couldn't solve the problem.
I didn't get energy from battery, I connected the edison to the power source.
Below is the log at booting.
U-Boot 2014.04 (Jun 06 2016 - 14:40:07)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
Flashing already done...
GADGET DRIVER: usb_dnl_dfu
reading vmlinuz
5461344 bytes read in 135 ms (38.6 MiB/s)
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.98-poky-edison+ (neck@flax) # 1 SMP PREEMPT Mon Jun 6 14:32:08 PDT 2016
Building boot_params at 0x00090000
Loading bzImage at address 00100000 (5445984 bytes)
Kernel command line: "rootwait root=PARTUUID=012b3303-34ac-284d-99b4-34e03a2335f4 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep loglevel=4 g_multi.ethernet_config=cdc systemd.unit=multi-user.target hardware_id=00 g_multi.iSerialNumber=f303f2be78eaae6ea044d65552a6b4ed g_multi.dev_addr=02:00:86:a6:b4:ed platform_mrfld_audio.audio_codec=dummy"
Starting kernel ...
[ 0.735765] pca953x 1-0020: failed reading register
[ 0.740883] pca953x 1-0021: failed reading register
[ 0.746023] pca953x 1-0022: failed reading register
[ 0.751069] pca953x 1-0023: failed reading register
[ 1.602720] snd_soc_sst_platform: Enter:sst_soc_probe
[ 2.086802] pmic_ccsm pmic_ccsm: Error reading battery profile from battid frmwrk
[ 2.096692] pmic_ccsm pmic_ccsm: Battery Over heat exception
[ 2.096771] pmic_ccsm pmic_ccsm: Battery0 temperature inside boundary
sh: cannot set terminal process group (-1): Inappropriate ioctl for device
sh: no job control in this shell
sh-4.3# [ 61.890969] snd_intel_sst: request fw failed
Does anyone knows what I should do to solve the problem?
Best,
k16
KNaga15
I reinstalled Yocto image. And it has solved.
KNaga15
