Intel® Makers
9881 Discussions
Intel edison mcu sdk
TKlae
since a couple of days I just try to install the linux 64 bit sdk for the intel edison mcu.
I tried to follow https://software.intel.com/en-us/node/545143# installing_mcu_sdk_linux Installing the MCU SDK | Intel® Software without success.
I think I understood I need to look at https://downloadcenter.intel.com/download/25028/Intel-Edison-Board-Support-Package?wapkw=edison+mcu Download Intel® Edison - Board Support Package
But then - which package I need to download? I assume https://downloadmirror.intel.com/25028/eng/edison-sdk-linux64-ww25.5-15.zip https://downloadmirror.intel.com/25028/eng/edison-sdk-linux64-ww25.5-15.zip , right?
If I execute the script inside that zip it installes something which doesn't look like a toolchain at "/opt/poky-edison/1.7.2/...". It looks more like a yocto fragment...
And which eclipse I need accordingly? And where to get it?
Since I've never used the mcu sdk befor the discontinoation notification I have completely no clue how to set up a working mcu sdk.
What I hope to end up with is a toolchain (compiler/binutils/libs) and an ide (or any strategy to build a working mcu application).
Any help on this is very welcome.
Thomas
Community Manager
Hello Thomas,
Thank you for your interest in the Intel Edison board.
Your request has been received and is currently being investigated.
We will get back to you as soon as possible.
Octavian
TKlae
Ok,
What I figured out is - the MCUSDK package belonging to https://software.intel.com/en-us/node/545143%23installing_mcu_sdk_linux is edison-mcusdk-linux64-1.0.10.zip. But for whatever reason this one isn't available anymore. Is there an alternative download location for it? Or does anybody has stored it an can forward it to me?
Thanks a lot.
Thomas
Community Manager
Hello Thomas,
We apologize for the late response.
Unfortunately due to Edison discontinuation some resources are unavailable at this time.
Again, we apologize for the late response and the inconvenience this may have caused.
Octavian
FerryT
Valued Contributor I
Yes, I have that. It's 238MB. I also have the win64 version (242MB).
If you share me a folder (google drive?) I can upload it for you. You can share it to mailto:fntoth@gmail.com fntoth@gmail.com
