Intel® Makers
9876 Discussions
Intel edison's internal atenna gain
TTHIÊ
I'm doing a project that calculate the distance based on the wifi's rssi . One pieces missing in the formula i 'm currently use is the antenna gain of the Intel edison .the access point is the Intel edison .Can someone tell me how can i acquire it ?
Thanks in advance .
Community Manager
Hello tringuyen112358,
Thank you for your interest in the Intel Edison Board.
I found maximum output levels of the Edison build-in antenna you require on https://communities.intel.com/thread/55080 https://communities.intel.com/thread/55080
I hope this information helps you! In case I can assist you with anything else, please let me know!
Thank you,
Eliza
Community Manager
Thank you,
Eliza
Community Manager
Could you please let me know if the information provided was helpful and if I can assist you with anything else?
Eliza
