Hello i have a problem with my intel galileo gen 2. i can't get an ip address. so what should i do if i need an ip address for using c/c++ eclipse for intel galileo gen 2?
Hi @marciarzky,
I would love to help you with this.
First, you need to connect your Galileo to a Serial Terminal and connect it to Wi-Fi (To do this you can follow this guide: https://software.intel.com/en-us/get-started-galileo-windows-step3 https://software.intel.com/en-us/get-started-galileo-windows-step3).
After you are connected to Wi-Fi, you can use the command ifconfig in the serial terminal, and you should get an output like this one:
The IP Address is in the red mark, now you can use that IP Address in Intel System Studio following this guide: https://software.intel.com/en-us/creating-an-ssh-connection-in-intel-system-studio-iot-edition https://software.intel.com/en-us/creating-an-ssh-connection-in-intel-system-studio-iot-edition)
I hope you find this information useful.
Leonardo R.
I've already done for first section that you mention. But still have an error. I can't see the USB port or FTDI port in my computer. So i can't input to putty
Hi @marciarzky,
You need to connect the FTDI cable (Like this one: http://www.ftdichip.com/Products/Cables/USBTTLSerial.htm), and install the recommended driver in the guide: http://www.ftdichip.com/Drivers/CDM/CDM%20v2.12.00%20WHQL%20Certified.exe.
After you have installed the driver, you should check the device manager to see if the USB Serial Port is recognized when you connect your device.
I found this guide that you can follow: https://software.intel.com/en-us/articles/getting-started-with-the-intel-galileo-board-on-windows, it is almost the same guide that I recommended you in the last reply.
If you still have issues, can you send me a screenshot of your device manager?
Have a nice weekend.
Leonardo R.
hi, thank's for guiding me before.
but i have many problem
the putty is still blank. i think, usb already connect and there is no problem with it
and i don't know why the bootable in sd card cannot open in serial monitor. so i cannot see login section and ip address too
how to fix it?
Hi @marciarzky,
It looks like you are following the steps for the Galileo Gen 1 of the guide that I gave you before ( https://software.intel.com/en-us/get-started-galileo-windows-step3), and you have to follow the steps for the Galileo Gen 2, so please follow this guide that I gave you in my last reply to avoid confusions: https://software.intel.com/en-us/articles/getting-started-with-the-intel-galileo-board-on-windows, you have to install the right FTDI driver to use the serial port, you should see USB Serial Port entry in the (COM & LPT) Ports section of the Device Manager whine you installed it successfully.
I hope you find this information helpful.
Leonardo R.
Hello @marciarzky,
Do you have any updates about this?
Pedro M.
