I wan't to use an interrupt but with a time-out of a given amount, let's say 0.5 seconds.
https://github.com/intel-iot-devkit/mraa/blob/master/examples/python/hello_isr.py mraa/hello_isr.py at master · intel-iot-devkit/mraa · GitHub
import mraa
import time
import sys
class Counter:
count = 0
c = Counter()
# inside a python interrupt you cannot use 'basic' types so you'll need to use
# objects
def test(gpio):
print("pin " + repr(gpio.getPin(True)) + " = " + repr(gpio.read()))
c.count+=1
pin = 6;
try:
x = mraa.Gpio(pin)
print("Starting ISR for pin " + repr(pin))
x.dir(mraa.DIR_IN)
# https://github.com/intel-iot-devkit/mraa/blob/master/examples/python/hello_isr.py https://github.com/intel-iot-devkit/mraa/blob/master/examples/python/hello_isr.py
x.isr(mraa.EDGE_RISING, test, x)
var = raw_input("Press ENTER to stop")
x.isrExit()
except ValueError as e:
print(e)
The http://iotdk.intel.com/docs/master/mraa/gpio_8h.html GPIO class on MRAA doesn't count with a function to set a timeout. If you want to set a timeout I suggest you to create a subroutine that checks the activity on the pin. For example with a loop structure; if the subroutine doesn't detect any trigger on the pin for a time the subroutine can close the loop.
Charlie
Charlie
This method uses polling with a time-out:
Change the @timeout(0.020) based on your application. Maximal recommended value is 0.035.
@timeout(0.020)
from functools import wraps
import errno
import os
import signal
# http://stackoverflow.com/questions/11901328/how-to-timeout-function-in-python-timeout-less-than-a-se... http://stackoverflow.com/questions/11901328/how-to-timeout-function-in-python-timeout-less-than-a-se...
class TimeoutError(Exception):
pass
def timeout(seconds=10, error_message=os.strerror(errno.ETIME)):
def decorator(func):
def _handle_timeout(signum, frame):
raise TimeoutError(error_message)
def wrapper(*args, **kwargs):
signal.signal(signal.SIGALRM, _handle_timeout)
signal.setitimer(signal.ITIMER_REAL,seconds) # used timer instead of alarm
try:
result = func(*args, **kwargs)
finally:
signal.alarm(0)
return result
return wraps(func)(wrapper)
return decorator
import mraa
import time
from timeout import timeout
trig = mraa.Gpio(3)
echo = mraa.Gpio(4)
trig.dir(mraa.DIR_OUT)
echo.dir(mraa.DIR_IN)
@timeout(0.020)
def distanceUS():
tZero = time.time()
# reading sensor in Python takes about 6 ms (US = Utrasonic Sensor)
# http://stackoverflow.com/questions/32300000/galileo-and-ultrasonic-error-when-distance-less-than-4cm http://stackoverflow.com/questions/32300000/galileo-and-ultrasonic-error-when-distance-less-than-4cm
# http://playground.arduino.cc/Main/UltrasonicSensor http://playground.arduino.cc/Main/UltrasonicSensor
trig.write(0)
time.sleep(0.000004) # in Arduino 2 microseconds, double this value to be sure
trig.write(1)
time.sleep(0.00001) # in Arduino 5 microseconds, double this value to be sure
trig.write(0)
sig = None
nosig = None
etUS = None
while echo.read() == 0:
nosig = time.time()
while echo.read() == 1:
sig = time.time()
if sig == None or nosig == None:
return 0
# et = Elapsed Time
etUS = sig - nosig
distance = etUS * 17150
return distance
while True:
try:
print distanceUS()
except Exception, e:
# print 'time out!'
continue
