Intel® Makers
9872 Discussions
IoT analytics don't show data
Community Manager
I configured an Intel Edison to trasmit data on IoT cloud. All look work fine and if I see in main page I can see many observations are sent:
But if I go in graphics, I don't see any data:
Why?
Greets,
Community Manager
Hi Ulixxes,
Could you please try with these steps to register the device again?
  1. Remove the device from the dashboard (in case you haven't before).
  2. Run "iotkit-admin reset-code && iotkit-admin reset-components && iotkit-admin initialize" on your Edison.
  3. Request de new device ID by entering "iotkit-admin device-id".
  4. Add the device device in dashboard using this device-id.
  5. Copy activation code from dashboard.
  6. Run "iotkit-admin test". What do you get after this?
  7. Run "iotkit-admin ".
  8. Start the iotkit agent now "systemctl enable iotkit-agent && systemctl start iotkit-agent".
Let us know your results.
-Pablo
Community Manager
Noone know why? It looks to be a platform bug..that is stopping me to continue a Intel project to show in next Maker Faire..
Community Manager
removing all and re-trying the procedure suggested in: https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics# installing_the_local_agent Intel® IoT Platforms: Getting Started: Cloud Analytics | Intel® Software
I neither can register the device. I'm surprised of that. But the Intel IoT cloud works there are pending issues?
Community Manager
Hi Ulixxes,
-Pablo
Community Manager
Well done!
I didn't understand exactly why the component is corrupted but after the command iotkit-admin reset-code && iotkit-admin reset-components && iotkit-admin initialize, I repeated all steps and sent again the datas: now works fine, both the registration and data charts:
Thank you very much!
Community Manager
Hi Ulixxes,
Glad to know the steps solved the issue
-Pablo
