Community
cancel
Showing results for
Search instead for
Did you mean:
DKay2
Is Figure 2 in 3.2 of Data sheet wrong?
Jump to solution
Referring to
Intel® Quark™ microcontroller D2000
January 2016 Datasheet
Document Number: 333577-002EN
In section 3.2 package diagrams - Figure 2 Pin 24 is marked as GPIO[25].
Can you confirm this is wrong and that it should be DVDD?
Michelle_C_Intel
Yes - That diagram is incorrect as per the table in Section 3.3 it should be DVDD_2
DVDD_2 and DVDD are identical and are to be connected to the same source.
The updated datasheet has an ammended diagram along with some other updates and it should be made public shortly ...
-- Michelle.
Michelle_C_Intel
-- Michelle.
DKay2
Thanks Michelle,
Lets hope the new data can be released soon. I'd be interested to know what other changes there are that could save us some development heart ache.
Are errata available to help meanwhile?
Would you consider adding a 'Revisions' section to the data sheet to identify what is changed. I found it hard to work out what the differences were between the Nov 2015 and Jan 2016 data?
