Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Is it possible to add RAM to edison breakout board?
I purchased an INTEL Edison Breakout Board Kit EDI2BB.AL.K. I see that there is 1GB RAM on the device.
I need more RAM for my application. Is there a way to add RAM to the board?
Diego_V_Intel
Hi systemc,
That's not possible. The RAM memory the SoC has cannot be changed. However, there are serial SRAM memories that you could use through the SPI interface, although I'm not sure if this kind of memories will help you since the ones I've seen before are up to 1Mbit: http://ww1.microchip.com/downloads/en/DeviceDoc/25142A.pdf http://ww1.microchip.com/downloads/en/DeviceDoc/25142A.pdf
Diego
Community Manager
Is there any version of Edison with 2GB or 4GB RAM? Is it planned for future?
Diego_V_Intel
Hi systemc,
Unfortunately, there aren't other versions of the Edison module, and currently, there aren't plans about releasing a different version of the module.
Diego
