Intel® Makers
9881 Discussions
Is it possible to clone the system of a "Compute Stick" (STK1A32WFC)?
EMARQ2
I just purchased several "Windows 10 INTEL Compute Stick" and I would like to deploy the installation I made on one of them. I was considering using Symantec Ghost to perform this cloning, but I have not found how to make "network boot". Is it expected?
Also, I tried to boot from a USB CD drive without success, is this normal?
Thanking you in advance for your answers.
Eric de Bordeaux
kfchoong
New Contributor II
I use Clonezilla (http://clonezilla.org http://clonezilla.org) which is based on Linux for cloning. The advantage is that it is free, just download and make a bootable USB. The disadvantage is that it is not very "user-friendly" compared to Windows-based apps.
EMARQ2
Thanks a lot for your advice.
Eric from Bordeaux
Community Manager
Hi Eric_de_bordeaux,
To answer your first question, yes it is expected because the Intel® Compute Stick does not have the wake on LAN option. It is possible to boot from USB CD drive, in order to help you with this could you please explain me more about the OS that you tried to install? Also, tell me if you get any error during the installation.
Hellen.
EMARQ2
Hi Hellen,
Thank you for your answer.
I think I did not use the correct terminology.
When I spoke about "network boot", I meant "Preboot Execution Environment".
I ask you to excuse my broken English.
To answer your last question ; After initializing the OS preloaded Windows 10 and have completed with applications and configurations I need, my administrator password no longer worked. I wanted to reset it with a boot CD Bart PE, but the Compute Stick doesn't recognize the USB drive and restarted automatically on its system.
I wish I could create an image of this configuration to clone it if needed.
Eric from Bordeaux
Community Manager
Hi Eric_de_BORDEAUX,
I am investigating about this; as soon as I get a method to do PXE with this compute stick, I will let you know the outcome.
Hellen.
Community Manager
To use PXE from the Intel® Compute Stick you need to choose wake on LAN option, and the Intel® Compute Stick doesn't have that option; but I did a lab using Clonezilla* as Choong suggested, it could help.
Here you can find information about, How to install and use Clonezilla
http://clonezilla.org/clonezilla-live.php http://clonezilla.org/clonezilla-live.php
Hope this helps.
Hellen.
EMARQ2
Thanks a lot Helen.
I'm going to use Choong method and I'll informe you about the results.
Best regards
Eric
Community Manager
I would like to know if you were able to resolve this problem.
Hellen.
Community Manager
I was checking this thread and I would like to know if there is any update with this.
Hellen.
