Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Is it possible to install Windows 7 on a Compute Stick? (and if yes, how)
I tried to install Windows 7 on my Compute Stick, but could never boot from a windows 7 media. I tried a micro SSD card with a bootable Win7 iso on it and also a Win7 Installation DVD (on an external USB DVD drive). But I could not find any way to boot from these.
Highlighted
Re: Is it possible to install Windows 7 on a Compute Stick? (and if yes, how)
There is a similar thread with information that can be of help for you.
Check it out:
/thread/68113 https://communities.intel.com/thread/68113
Highlighted
Check it out:
Highlighted
The problem seems to be that the Intel Stick does not recognize any of my Windows 7 bootable media (DVD, SSD). Hence I can't boot from them and can't install.
Highlighted
Highlighted
Highlighted
Highlighted
Why do you want to install Windows 7? The driver support will be crappy, if you can even get it installed.
Highlighted
Highlighted
That would be my comment as well. Even if you were able to get Windows 7 loaded, you're not likely to find compatible drivers.
Highlighted
Highlighted
Highlighted
Highlighted
Hello, need advice. Wanna reinstall Windows an Intel Compute Stick CS125. On the site where I bought, it is written that the native Windows 10 pro, is it better to install it or another?
