Intel® Makers
9881 Discussions
Is it possible to use the grove kit with node-red on Windows 10 or Ubuntu x64?
AndreCarlucci
Black Belt
Node-red runs fine on Windows 10, but I couldn't install module mraa on Windows 10.
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:343:16)
gyp ERR! stack at ChildProcess.emit (events.js:110:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)
gyp ERR! System Windows_NT 6.3.9600
gyp ERR! command "node" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\andrecarlucci\AppData\Roaming\npm\node_modules\mraa
gyp ERR! node -v v0.12.2
gyp ERR! node-gyp -v v1.0.3
gyp ERR! not ok
npm ERR! Windows_NT 6.3.9600
npm ERR! argv "C:\\Program Files (x86)\\nodejs\\\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "-g" "mraa"
npm ERR! node v0.12.2
npm ERR! npm v2.7.4
npm ERR! code ELIFECYCLE
npm ERR! mraa@1.3.0 install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the mraa@1.3.0 install script 'node-gyp rebuild'.
npm ERR! This is most likely a problem with the mraa package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls mraa
npm ERR! There is likely additional logging output above.
On Ubuntu x64 I went as far as running node-red and got this error:
Welcome to Node-RED
3 Oct 14:40:37 - [info] Node-RED version: v0.14.6
3 Oct 14:40:37 - [info] Node.js version: v6.7.0
3 Oct 14:40:37 - [info] Linux 3.4.0+ x64 LE
3 Oct 14:40:37 - [info] Loading palette nodes
3 Oct 14:40:38 - [warn] ------------------------------------------------------
3 Oct 14:40:38 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
3 Oct 14:40:38 - [warn] [upm-grove-button] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
3 Oct 14:40:38 - [warn] [upm-grove-led] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
3 Oct 14:40:38 - [warn] [upm-grove-light] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
3 Oct 14:40:38 - [warn] [upm-grove-relay] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
3 Oct 14:40:38 - [warn] [upm-grove-rgb-lcd] Error: /usr/lib/node_modules/jsupm_i2clcd/jsupm_i2clcd.node: wrong ELF class: ELFCLASS32
Any thoughts?
Community Manager
Hi Andre,
Thank you for contacting us, let us try to help you solve the issue.
Which commands are you using to install mraa and where are you getting it from? Did you get it from source or from AlexT's repository? Let us know every detail from your process to see if we can spot the issue or at least help you in getting it solved.
-Pablo
AndreCarlucci
Black Belt
Hi Pablo, thanks for your help.
On Windows 10
This is what I get when running node-red:
andrecarlucci@CARLUCCI-WAY2 C:\dev\labs\node-red
$ node-red
Welcome to Node-RED
4 Oct 15:53:38 - [info] Node-RED version: v0.14.6
4 Oct 15:53:38 - [info] Node.js version: v0.12.2
4 Oct 15:53:38 - [info] Windows_NT 6.3.9600 ia32 LE
4 Oct 15:53:38 - [info] Loading palette nodes
4 Oct 15:53:40 - [warn] ------------------------------------------------------
4 Oct 15:53:40 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
4 Oct 15:53:40 - [warn] [tail] Not currently supported on Windows.
4 Oct 15:53:40 - [warn] [upm-grove-button] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-led] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-light] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-relay] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-rgb-lcd] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-rotary] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-sound] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-temperature] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-grove-servo] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [warn] [upm-curieimu] Error: Cannot find module 'mraa'
4 Oct 15:53:40 - [info] Settings file : C:\Users\andrecarlucci\AppData\Roaming\npm\node_modules\node-red\settings.js
4 Oct 15:53:40 - [info] User directory : \Users\andrecarlucci\.node-red
4 Oct 15:53:40 - [info] Flows file : \Users\andrecarlucci\.node-red\flows_CARLUCCI-WAY2.json
4 Oct 15:53:40 - [info] Creating new flow file
4 Oct 15:53:40 - [info] Starting flows
4 Oct 15:53:40 - [info] Started flows
4 Oct 15:53:40 - [info] Server now running at http://127.0.0.1:1880/
4 Oct 15:53:44 - [info] Stopping flows
Terminate batch job (Y/N)? Y
npm install -g mraa
See attached document for logs.
On bash for Windows 10 (Ubuntu):
mraa installs just fine.
When I type node-red, I get this:
andrecarlucci@CARLUCCI-WAY2:~/node-red$ node-red
Welcome to Node-RED
4 Oct 18:49:58 - [info] Node-RED version: v0.14.6
4 Oct 18:49:58 - [info] Node.js version: v6.7.0
4 Oct 18:49:58 - [info] Linux 3.4.0+ x64 LE
4 Oct 18:49:58 - [info] Loading palette nodes
4 Oct 18:50:05 - [warn] ------------------------------------------------------
4 Oct 18:50:05 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
4 Oct 18:50:05 - [warn] [upm-grove-button] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-grove-led] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-grove-light] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-grove-relay] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-grove-rgb-lcd] Error: /usr/lib/node_modules/jsupm_i2clcd/jsupm_i2clcd.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-grove-rotary] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-grove-temperature] Error: /usr/lib/node_modules/jsupm_grove/jsupm_grove.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-grove-servo] Error: /usr/lib/node_modules/jsupm_servo/jsupm_servo.node: wrong ELF class: ELFCLASS32
4 Oct 18:50:05 - [warn] [upm-curieimu] Error: Cannot find module 'jsupm_curieimu'
4 Oct 18:50:05 - [info] Settings file : /home/andrecarlucci/.node-red/settings.js
4 Oct 18:50:05 - [info] User directory : /home/andrecarlucci/.node-red
4 Oct 18:50:05 - [info] Flows file : /home/andrecarlucci/.node-red/flows_CARLUCCI-WAY2.json
4 Oct 18:50:05 - [info] Creating new flow file
4 Oct 18:50:05 - [info] Starting flows
4 Oct 18:50:05 - [info] Started flows
4 Oct 18:50:05 - [info] Server now running at http://127.0.0.1:1880/
I'm using npm repository.
Btw, I'm trying to make my Arduino 101 with Grove to work directly with my notebook, I don't actually have an Edson board.
Thanks!
Community Manager
Hi Andre,
I'm still not sure what you're exactly trying to achieve with your project, and I would like to first clarify on that. Could you please answer the following questions?Also, remember that the Arduino Support team is the one in charge of handling the Arduino 101 cases, so it might be a good idea to let them know your questions, here's the link https://forum.arduino.cc/index.php?board=103.0 https://forum.arduino.cc/index.php?board=103.0.
-Pablo
Community Manager
Hi Andre,
I'm wondering if you received a notification for our last post in this thread. Have you been able to work on this case lately? Do you have any updates? I would like to help you with this so I would appreciate if you could answer the questions from my previous post.
-Pablo
