Intel® Makers
9880 Discussions
Is there a way to restart the stick using command prompt while on a domain?
TBlaa
I have setup the stick and put it on our domain, I'd like to be able to control it remotely as well as restart if necessary. They want to be able to reach the stick and then open files on a share, like Powerpoint.
Is this possible, can anyone help me with the command line instructions?
Thanks!
EOcho1
shutdown /r from a command prompt will restart the machine.
for remote access try VNC, or LogMein, or Splashtop.
EstebanA_C_Intel
Hello, Blaaamo:
Thank you for contacting the Intel Communities.
In addition to cwizardtx answer which is very helpful, please keep in mind the capabilities of the software that you are using to access the device remotely or will be used, this is to check if the software is able to start the remote connection without anything to be started first in the system directly (after restart).
If you require any further information or support, do not hesitate to contact us back.
Esteban C
