Intel® Makers
9881 Discussions
Is there a way to send matlab data to Intel Galileo
RNara1
I have my data in matlab which i want to tranfer it to Galileo for further actions, could you please help me out with this?
Diego_V_Intel
Hi Shoban_Narayan,
I'm afraid that connecting the Galileo board with MATLAB is not possible. As you can see in the following threads from MathWorks* forum, the Galileo board is not supported by MATLAB so it's not possible to send data to the board:
Diego
Diego_V_Intel
Hi Shoban_Narayan,
Diego
JTurn12
New Contributor II
What type of data is it though?
Depending on what you want to do, it may be possible. For example, a vector array as a txt file would be possible.
I have sent a file like this from an arduino into a PC and imported it manually into MATLAB. Your task seems a bit more complicated but It can be accomplished with a python script of some sort.
Good luck
RNara1
Yes it is vector array of txt datatype, but I must automize the transfer of files between PC and Galileo through coding.
FTinetti
Honored Contributor I
What about the following sequence?:
a) generate .txt file in matlab
b) have a program that once recognized the .txt file exists, sends it to somewhere (Galileo in this case) and rename/delete the file
you could add a "signal" to the program sending the .txt file...
I'm curious why you need to send data from a PC to the Galileo... the "usual" data flow I've seen is in the opposite direction: from Galileo or Arduino to PC except in configuration startup at the Galileo or Arduino.
Fernando.
JTurn12
New Contributor II
MATLAB has some FTP operations, so if your Galileo is on the same LAN you should be able to send the file that way.
http://www.mathworks.com/help/matlab/ref/ftp-class.html http://www.mathworks.com/help/matlab/ref/ftp-class.html
FTinetti
I did not work much with matlab, you clearly know better, this is far easier than my "proposal".
Fernando.
