Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Is there any unique ID with each Quark Se C1000?
I need that each quark se c100 has a unique ID. This ID is used in the program as an identifier when transmitting through the RF module.Want to access it in flash programmed so that each quark node has a unique ID.
There is read-only Identification Register (IDR), is it contains unique value for each chip of quark se c1000?
