Intel® Makers
9873 Discussions
Is there any way to use a bluetooth keyboard to wake the STK2m3W64CC from sleep?
JJanK
I'm using a Rapoo E6700 keyboard for my Win 10 Compute Stick, but I'm unable to wake the Stick from sleep with it. Is there anything I can do to make this work?
Community Manager
Hello Kashaar:
In this case we can try a BIOS update to the latest version and also re-install the Bluetooth driver.
F7 method to do a BIOS update:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005724.html http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005724.html
This is the .BIO file needed to do the update:
https://downloadcenter.intel.com/download/26390/BIOS-Update-CCSKLm30-86A- https://downloadcenter.intel.com/download/26390/BIOS-Update-CCSKLm30-86A-
On the following link you will find the Bluetooth driver, please try that driver:
https://downloadcenter.intel.com/download/26112/Intel-Bluetooth-Technology-Based-Driver-for-Intel-Co... https://downloadcenter.intel.com/download/26112/Intel-Bluetooth-Technology-Based-Driver-for-Intel-Co...
Additionally you will find an option on the BIOS that says "wake device from S5 state", please make sure that option is enable.
Alberto
n_scott_pearson
Super User Retired Employee
For the Bluetooth driver, it is best to (1) uninstall existing driver, (2) reboot the NUC and then (3) (re-)install the latest driver.
Community Manager
Hello:
Thank you very much to N.Scott.Pearson for the advice provided above.
To Kashaar:
Please try suggestion above and let us know the results.
Alberto
JJanK
I tried all three of these suggestions, but none of them seem to have had an effect. Anything else I could try?
Could it perhaps be a device incompatibility? I could perhaps try and borrow a friend's bluetooth keyboard and see if it makes a difference.
Community Manager
Hello Kashaar:
In regard to your inquiry, yes, it could be a compatibility problem between the stick and the keyboard, there has been some cases when the Bluetooth keyboard gets connected to stick but because of compatibility not all of the features work as they should.
Since you have the option to use a different Bluetooth keyboard, please try that and let us know the results.
Alberto
Community Manager
Hello Kashaar:
I just wanted to check if you were able to test the stick with a different Bluetooth keyboard, and if the problem was resolved or if it still persists?
Also, on the following link you can confirm that the Bluetooth keyboard should wake the stick from sleep S3 state, page 16:
http://www.intel.com/content/dam/support/us/en/documents/boardsandkits/computestick/STK2m3W64CC_STK2... http://www.intel.com/content/dam/support/us/en/documents/boardsandkits/computestick/STK2m3W64CC_STK2...
Any questions please let know.
Alberto
Community Manager
Hello Kashaar:
We hope the issue with the Bluetooth keyboard got resolved.
If you need further assistance with this case please let me know.
Alberto
AAnth3
I have the same problem.
NUC5i3RYH, all drivers up to date.
Microsoft Wedge Keyboard.
Not possible to wake from S3.
"Allow device to wake computer" is grayed in device manager.
Community Manager
Hello GabrielLogan:
In this case, in order for us to provide the best assistance we can regarding the NUC you are using, please submit your inquiry on a new thread; by doing that, we can start from scratch in trying to fix the specific problem your NUC has, and also in the case we need to start an investigation or if we need to replicate the issue.
Alberto
