Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Is there source code for Intel Curie Module SDK?
Is there any source available for this? We have an old iOS project that was built using their SDK. This Intel SDK for iOS was built using 2.3 and is not compatible with Swift 4.0. Is there any way to use this SDK in a current iOS project?
Tags (1)
Highlighted
Community Manager
Hello casey55,
Thank you for your interest in the Intel Curie Module.
You can find information on the SDK on the following link:
https://software.intel.com/en-us/node/675000
Let me know if this proves helpful.
Casandra
Highlighted
Is there a repo that has the source code for the IQCore Framework for iOS, so we can rebuild it so it is compatible with Swift 4.0?
Highlighted
Community Manager
Hello casey55,
I cannot find a similar use case to yours.
Could you give me more details as to what exactly you are trying to accomplish with the Intel Curie Module?
Intel Curie Module SDK information might be available here: https://github.com/CurieBSP/main
Let me know if this is useful.
Thank you in advance for your answer,
Casandra
Highlighted
We are using the BodyRefApp the "Intel Core SDK, Body IQ, and Reference Application for iOS". This project is built using swift 2.3 and the Intel SDK IQCore that it links to is built using Swift 2.3. We are wanting to access this SDK with a current Swift 4.0 app, but it's not possible unless the SDK is updated to Swift 4.0 too. Is there a link to the SDK source code, so we can rebuild it using Swift 4.0?
Thanks!
Highlighted
Community Manager
Hello casey55,
Thank you very much for your patience in receiving a response.
We have researched your query and unfortunately, we could not find any information about an "Intel SDK IQCore", we are not familiar with such tool. Is it possible you might be referring to the XDK?
XDK has unfortunately been discontinued.
There is the Curie ODK (Open Developer Kit) https://software.intel.com/en-us/node/675000 https://software.intel.com/en-us/node/675000, and also the Curie BSP (Board Support Package) available on GitHub https://github.com/CurieBSP/main https://github.com/CurieBSP/main that I have mentioned in my previous post.
There is also the pattern matching library https://github.com/intel/Intel-Pattern-Matching-Technology https://github.com/intel/Intel-Pattern-Matching-Technology, if by any chance this is what you are looking for.
If these resources are not what you were hoping to get then, it is most likely that the resource you are looking for is not available, we apologize for the inconvenience this may have caused.
Please also keep in mind that the Intel Curie has been discontinued.
Let me know if there is anything else I can assist you with further.
Casandra
Community Manager
Hi casey55,
Was the provided answer helpful?
Do you have further questions?
Alexandra
