In Edison_arduino_hvm_8_26.pdf (http://www.intel.com/content/www/us/en/support/boards-and-kits/000005829.html Schematics for the Intel® Edison Board for Arduino* ), U35 (TXS206-29) is confusing to me
I can't find info regarding TXS206-29. Is U35 referring to TXS0206 instead of TXS206-29?
If it is, then
1) VBATT@ B2, according to TI's documentation (http://www.ti.com/lit/ds/symlink/txs0206.pdf http://www.ti.com/lit/ds/symlink/txs0206.pdf ) , should be CD, not VBATT
2) VCCB@B3 doesn't connect to anything on your schematic, but TI says it should be the B-port supply voltage
3) WP/CD@A3 should be WP according to TI (but this doesn't cause any problem in the application)
Can you verify? Thanks!
Hi Saxe,
Thanks for your interest in Intel Edison.
I was looking for the information you need and I found the datasheet regarding TXS206-29, here is the link: http://www.ti.com/lit/ds/symlink/txs0206-29.pdf http://www.ti.com/lit/ds/symlink/txs0206-29.pdf. To summarize your questions:
- The terminal B2 in TXS206-29 corresponds to VBATT
- The terminal B3 (VCCB) is connected to the VDD in the SD CONN G46739-001 (Refers to the Edison schematic)
- The terminal A3 is both WP/CD
Hope this information helps, if you have any other question, please let us know.
-Yermi
Hi Saxe,
-Yermi
OK, it is TXS0206-29, not TXS206-29, that's why I can't find the data sheet
thanks
Hi Saxe,
You're welcome, I'm glad that it helped, if you have any other question, please let me know.
-Yermi
Maybe you should fix the typo on your schematic, otherwise, someone may fall into the same trap when googling TXS206
Hi Saxe,
Thanks for your suggestion, I really appreciate it.
I'll send your suggestion to the appropriate team
-Yermi
