Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Issue to write on serial
I'm try to use the USB serial port, but I have some issue to send data from PC to Edison using mraa
I init the port in follow way:
uart = mraa_uart_init_raw("/dev/ttyGS0");
mraa_uart_set_baudrate(uart, 9600);
mraa_uart_set_mode(uart, 8,MRAA_UART_PARITY_NONE , 1);
mraa_uart_set_flowcontrol(uart, 0, 0);
mraa_uart_set_timeout(uart, 1, 1, 1);
and after in a function I check the availabily of new data and I read the bytes one by one:
// while data availablewhile( mraa_uart_data_available(uart,1)){
// read 1 byte from serialnumread = mraa_uart_read(uart, data, 1)
// if something read
if (numread > 0)
This strategy is because I don't want block the program on the reading and get bytes only when data is available.
But, when I send the data from PC (using a serial terminal like Arduino monitor or a C# program create by myself), the reading not work correctly: most part of time don't read anything, sometime get 1 or 2 bytes.
The communication is ok, because if I send data from Edison to PC it works great. Furthermore I used same strategy to read and write data from a sensor on HW serial on Edison (pin 0 and 1) and worked well.
Only problem when I try to send data from PC over USB. What could be the issue?
Community Manager
Hi Ulixxes,
Thanks for contacting us,
I believe ttyGS0 is not available on mraa. As you can see in this link http://iotdk.intel.com/docs/master/mraa/edison.html http://iotdk.intel.com/docs/master/mraa/edison.html, the available UART interface is on /dev/ttyMFD1, so you might test using an FTDI cable connecting to TX (1) and RX (0) and then use a terminal to see the UART communication.
On the other hand, I would like to know how you are sending data from the Edison to PC.
I'll be waiting your reply in order to help you.
-Yermi
Community Manager
Hi Ulixxes,
I would like to know if you have any updates. Were you able to send data from the PC to Edison successfully?
-Yermi
Community Manager
Unfortunately no.
Anyway I can't use the pin 0/1 serial because is busy for a serial sensor.
I'm surprised that I can't use the USB serial as communication to PC..
Anyway, about your previous question to send from Edison to PC with the USB serial port looks to work:
I'm using Eclipse tool, but if I use the Arduino IDE isn't the same than use Serial.print()?????
here the extract of init port:
uart = mraa_uart_init_raw("/dev/ttyGS0");mraa_uart_set_baudrate(uart, 9600);mraa_uart_set_mode(uart, 8,MRAA_UART_PARITY_NONE , 1);
and here of send serial:
// send datareturn mraa_uart_write(uart, data, strlen(data));
Community Manager
Hi Ulixxes,
Thanks for all the information that you have shared.
I made some tests using /dev/ttyGS0 port, and I'm having the same issue, I'm able to send data from the Edison to the PC, but vice-versa, I got the same behavior, sometimes the data is lost and others it is read. So, let me investigate a little bit more in order to help you with that.
I'll appreciate your patience, also if you have any update, let me know please.
Yermi.
Brendan_L_Intel
you'll need to kill clloader, there's a systemd service called galileo-target or similar running and use systemctl stop and systemctl disable . That should enable you to have two way communication.
