Intel® Makers
9873 Discussions
Issue with MQTT with Paho on Intel Galileo
Community Manager
I was starting to feel sorry for my 2 Intel Galileo boards as they haven't seen much action for a while so I decided to build some example scripts for my Python module that allows devices to connect to my developer platform via Paho. The package has the required certificate included that is required to connect to the MQTT broker (and works with no issues on Raspberry Pi) but I am getting the following error, does anyone have any ideas how to resolve this issue, I finally have some plans for the two boards and hit a road block straight away.
python IntelGalileoDevice.py
Traceback (most recent call last):
File "IntelGalileoDevice.py", line 55, in
JumpWayPythonMQTTDeviceConnection.connectToDevice()
File "/usr/lib/python2.7/site-packages/techbubbleiotjumpwaymqtt/device.py", line 58, in connectToDevice
self.mqttClient.connect(self.mqttHost,self.mqttPort,10)
File "/usr/lib/python2.7/site-packages/paho/mqtt/client.py", line 612, in connect
return self.reconnect()
File "/usr/lib/python2.7/site-packages/paho/mqtt/client.py", line 747, in reconnect
ciphers=self._tls_ciphers)
File "/usr/lib/python2.7/ssl.py", line 381, in wrap_socket
ciphers=ciphers)
File "/usr/lib/python2.7/ssl.py", line 143, in __init__
self.do_handshake()
File "/usr/lib/python2.7/ssl.py", line 305, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [Errno 1] _ssl.c:506: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
The module can be found here:
https://github.com/AdamMiltonBarker/TechBubble-Iot-JumpWay-Python-MQTT GitHub - AdamMiltonBarker/TechBubble-Iot-JumpWay-Python-MQTT: TechBubble IoT JumpWay Python MQTT Module
Community Manager
Solved this it was the time settings had to issue:
date mmddhhmmYY
Community Manager
date mmddhhmmYY
