Community
cancel
Showing results for
Search instead for
Did you mean:
MD7
Issue with video streaming using ffmpeg
Hi
I have a USB Webcam (Logitech C270) connected to a Edison board.
I would like to stream the video and access it from an internet browser
The edison-image-ww18-15 image is installed on the Edison
Here is an extraction of the shell window
 root@edison:~# node edi-cam/web/server/server.js & [1] 356 root@edison:~# WebSocket server listening on port 8084 HTTP server listening on port 8080 Listening for video stream on port 8082 edi-cam/bin/do_ffmpeg.sh ffmpeg version 2.6.3- http://johnvansickle.com/ffmpeg/ http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2015 the FFmpeg developers  built with gcc 4.9.2 (Debian 4.9.2-16)  configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --cc=gcc-4.9  libavutil 54. 20.100 / 54. 20.100  libavcodec 56. 26.100 / 56. 26.100  libavformat 56. 25.101 / 56. 25.101  libavdevice 56. 4.100 / 56. 4.100  libavfilter 5. 11.102 / 5. 11.102  libswscale 3. 1.101 / 3. 1.101  libswresample 1. 1.100 / 1. 1.100  libpostproc 53. 3.100 / 53. 3.100 Input # 0, video4linux2,v4l2, from '/dev/video0':  Duration: N/A, start: 51.807801, bitrate: 36864 kb/s  Stream # 0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 320x240, 36864 kb/s, 30 fps, 30 tbr, 1000k tbn, 1000k tbc Please use -b:a or -b:v, -b is ambiguous Stream Connected: 127.0.0.1:35276 size: 320x240 Output # 0, mpeg1video, to 'http://127.0.0.1:8082': http://127.0.0.1:8082':  Metadata:  encoder : Lavf56.25.101  Stream # 0:0: Video: mpeg1video, yuv420p, 320x240, q=2-31, 800 kb/s, 30 fps, 30 tbn, 30 tbc  Metadata:  encoder : Lavc56.26.100 mpeg1video Stream mapping:  Stream # 0:0 -> # 0:0 (rawvideo (native) -> mpeg1video (native)) Press [q] to stop, [?] for help frame= 18 fps=0.0 q=2.0 size= 66kB time=00:00:00.53 bitrate=1013.0kbits/s frame= 33 fps= 33 q=2.0 size= 123kB time=00:00:01.03 bitrate= 972.2kbits/s frame= 48 fps= 32 q=2.0 size= 176kB time=00:00:01.53 bitrate= 940.6kbits/s frame= 63 fps= 31 q=2.0 size= 238kB time=00:00:02.03 bitrate= 958.5kbits/s frame= 79 fps= 31 q=2.0 size= 295kB time=00:00:02.56 bitrate= 941.0kbits/s frame= 94 fps= 31 q=2.0 size= 349kB time=00:00:03.06 bitrate= 931.3kbits/s frame= 109 fps= 31 q=2.0 size= 401kB time=00:00:03.56 bitrate= 921.4kbits/s frame= 124 fps= 31 q=2.1 size= 464kB time=00:00:04.06 bitrate= 934.4kbits/s frame= 139 fps= 31 q=2.0 size= 517kB time=00:00:04.56 bitrate= 926.7kbits/s frame= 154 fps= 31 q=2.0 size= 571kB time=00:00:05.06 bitrate= 922.6kbits/s frame= 169 fps= 30 q=2.0 size= 626kB time=00:00:05.56 bitrate= 921.8kbits/s
In shell, everything looks ok and Webcam LED turn ON after sending these commands
But in the internet browser, I don't see anything except a white rectangular (empty)
Any idea why I don't see anythin on the browser ?
Pablo_M_Intel
Hi Wavics,
Are you using the Arduino Breakout board or the Mini Breakout board?
Regarding the process, what steps are you following to make the webcam work?
PabloM_Intel
MD7
Hi Pablo,
I use the Arduino Breakout board.
I have node.js running on the platform and try to stream the video using ffmpeg.
Here is the status :
- I manage to save the video in an output file using ffmpeg
- I do not manage to stream it on my PC internet browser using ffmpeg. The PC is connected to the Edison through a router
Wavics
JesusE_Intel
Hi Wavics,
Are you using the edi-cam from https://github.com/drejkim/edi-cam drejkim/edi-cam · Github?
I also had a similar issue, the node.js would be running and the webcam LED was on. When i loaded the nodejs server in a web browser using the IP address it would say loading or simply a blank screen. How are you addressing the server in the browser? Depending on your network configuration your address should be something like http://192.168.1.2:8080
Also, did you update the websocket address in the web/client/index.html?
Mine was something like var wsUrl = 'ws://192.168.1.2:8084/';
If that does not work, i suggest you to re-flash your Edison.
Jesus
msoni1
hey Wavics,
I am also following the same tutorial. I got my camera configured and get live streaming through websocket.
I also want to capture image and store that on edison. can you help me with this.?
Malay
Pablo_M_Intel
Hi Malay_soni,
I saw that you already have an opened case discussing the same issue that you asked here. So we will continue providing you support in that thread /thread/87420 https://communities.intel.com/thread/87420.
PabloM_Intel
jjun
Hi, I am also unable to show the image on the webserver following this tutorial: http://www.instructables.com/id/Edison-monitoring-system-with-motion-detection-and/?ALLSTEPS Edison monitoring system with motion detection, cloud connection and video streaming - All
My web server is able to run with a blank image.
Following Step 3: Configure web server for streaming the video across the network
I've created directories as followed using groupadd and useradd
Next, i did not fully understood "Copy the web server autostart script into /etc/init.d to have it started on OS boot."
I skipped this step since the motion-webserver script is already in it after i git clone this repo, am i doing it right?
Next, i cp 'scripts' from edison-mon-sys/home/motion over to /home/motion/
Next, i did a npm install in home/motion/scripts
However there is a warning line displayed: npm WARN package.json motion-edison-demo-webserver@0.1.0 No repository field.
Lastly, i change the IP address in index.html to http://(board/ http://(board/ IP):10080 as followed and did a node server.js however its a blank image.
Can anyone guide me what did i do wrong?
Pablo_M_Intel
Hi mr_crocodile556,
I haven't tried the process that you mention, but I've been able to implement this one https://github.com/drejkim/edi-cam https://github.com/drejkim/edi-cam. Have you tried with this one? Node.js is used in both processes so I believe you won't have any issues with that.
Pablo
jjun
Thank you, yes i am able to implement the one on edi-cam as well, however i would like to add in a motion detecting function for my project.
Since, the one on edi-cam did not have motion detecting function,i tried to follow through http://www.instructables.com/id/Edison-monitoring-system-with-motion-detection-and/?ALLSTEPS Edison monitoring system with motion detection, cloud connection and video streaming - All
and re created a new web server with that tutorial.
Do you have any idea how do i add in motion detecting function to my camera?
Pablo_M_Intel
Hi mr_crocodile556,
Have you checked this guide before? http://www.instructables.com/id/Motion-Activated-Security-Camera-using-Intel-Ediso/ http://www.instructables.com/id/Motion-Activated-Security-Camera-using-Intel-Ediso/. You could even try to implement the motion section of the first tutorial you mentioned, but using the webserver from the one I shared with you. It should be possible to mix them both.
Pablo
jjun
Thank you for the useful link,
I tried implementing http://www.instructables.com/id/Edison-monitoring-system-with-motion-detection-and/?ALLSTEPS Edison monitoring system with motion detection, cloud connection and video streaming - All and i faced a problem here
Under Step 2:Configure Motion,
I followed the instruction and pasted motion.conf file download from his repo into /etc
Next, i put the init.d directory into /etc.
That should be all for Step 2 right?
However when i run the command of "motion" to test it out i received the following error
[0] Processing thread 0 - config file /etc/motion.conf [0] Unknown config option "ffmpeg_cap_new" [0] Unknown config option "ffmpeg_cap_motion" [0] Unknown config option "ffmpeg_timelapse" [0] Unknown config option "ffmpeg_timelapse_mode" [0] Unknown config option "ffmpeg_bps" [0] Unknown config option "ffmpeg_variable_bitrate" [0] Unknown config option "ffmpeg_video_codec" [0] Unknown config option "ffmpeg_deinterlace" [0] Unknown config option "movie_filename" [0] Unknown config option "timelapse_filename" [0] Motion 8.4.0 Started [0] Thread 1 is from /etc/motion.conf [0] motion-httpd/8.4.0 running, accepting connections [1] Thread 1 started [0] motion-httpd: waiting for data on port TCP 8080 [1] cap.driver: "uvcvideo" [1] cap.card: "UVC Camera (046d:0825)" [1] cap.bus_info: "usb-dwc3-host.2-1" [1] cap.capabilities=0x84000001 [1] - VIDEO_CAPTURE [1] - STREAMING [1] Test palette MJPG (640x480) [1] Using palette MJPG (640x480) bytesperlines 0 sizeimage 341333 colorspace 00000008 [1] found control 0x00980900, "Brightness", range 0,255 [1] "Brightness", default 128, current 128 [1] found control 0x00980901, "Contrast", range 0,255 [1] "Contrast", default 32, current 32 [1] found control 0x00980902, "Saturation", range 0,255 [1] "Saturation", default 32, current 32 [1] found control 0x00980913, "Gain", range 0,255 [1] "Gain", default 64, current 64 [1] mmap information: [1] frames=4 [1] 0 length=341333 [1] 1 length=341333 [1] 2 length=341333 [1] 3 length=341333 [1] Using V4L2 [1] Resizing pre_capture buffer to 1 items Corrupt JPEG data: 1 extraneous bytes before marker 0xd1 Corrupt JPEG data: 5 extraneous bytes before marker 0xd7 Corrupt JPEG data: 1 extraneous bytes before marker 0xd2 Corrupt JPEG data: 1 extraneous bytes before marker 0xd5 Corrupt JPEG data: 3 extraneous bytes before marker 0xd0
It is a continuous script that runs unless i Ctrl+C which outputs this error eventually
module.js:340  throw err;  ^ Error: Cannot find module 'temboo/core/temboosession'  at Function.Module._resolveFilename (module.js:338:15)  at Function.Module._load (module.js:280:25)  at Module.require (module.js:364:17)  at require (module.js:380:17)  at Object. (/home/motion/scripts/xively_post.js:37:16)  at Module._compile (module.js:456:26)  at Object.Module._extensions..js (module.js:474:10)  at Module.load (module.js:356:32)  at Function.Module._load (module.js:312:12)  at Function.Module.runMain (module.js:497:10) [0] httpd - Finishing [0] httpd Closing [0] httpd thread exit [0] Motion terminating
Are you able to help me look through the tutorial for me under Step 2 in the link provided above?
Thank you.
Pablo_M_Intel
Hi mr_crocodile556,
I see that you're trying to create an init script, but according to the tutorial creating a system service is also a possibility, have you tried this? As it is mentioned in the tutorial, it would be better to use system as Edison uses it as its primary system control. I would suggest you to check this thread, /thread/60537 https://communities.intel.com/thread/60537. You can also take a look at the other services to see how it should be written and the instructions it should have.
Pablo
