Intel® Makers
9880 Discussions
Issues with Docker when setting up ISS-IoT in Linux -- Intel Joule
Community Manager
I was advised to redirect this thread from the base Intel Joule forum to this one. Please see below.
I am attempting to get my development environment configured to the point where I can compile and run the provided examples (Hello_World.cpp, specifically). I am following along with the setup instructions at https://software.intel.com/en-us/node/642105 IoT - Setting up the Intel® System Studio IoT Edition (Linux*) | Intel® Software to configure the development environment in Linux.
Once I get to the end of the Create a new Project step, I am met with a popup that says "Could not create the Docker container for the selected project". I followed the installation steps at the top of the instructions exactly, and can confirm that executing `docker ps` returns the expected output (based on the instructions).
Some details about my environment:
Ubuntu Linux 14.04 running in a virtual machine
$ docker -v
Docker version 1.6.2, build 7c8fca2
$ java -version
java version "1.8.0_101"
Java(TM_ SE Runtime Environment (build 1.8.0_101-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)
Some terse Googling didn't come up with any other instances of this Docker error. Is there some other dependency that I may be lacking due to Ubuntu version or anything? I've seen explicit mention of using 16.04 in another thread here regarding cross-compilation ( ), which is a longer-term goal of mine as well.
Many thanks in advance,
EDIT: One possibility is that docker, because it requires virtualization itself, can not be used within a virtual machine? I'm afraid I'm not familiar enough with docker to flush this thought out much more, but I'll continue to look into it and update this thread if I find anything interesting.
Community Manager
Hi Scott,
Thanks for your interest in the Intel® Joule Platform.
We appreciate all the information provided, and we would like to let you know that we are going to investigate a little bit more your issue and as soon as we find useful information we'll let you know.
We'll appreciate your patience during the meantime.
-Yermi
Community Manager
Hello Yermi,
Thank you for your acknowledgement.
It actually looks like I have nobody to blame but myself: I've since tried upgrading by Ubuntu Linux distribution from 14.04 to 16.04 (which your setup guide lists as a requirement) and am already seeing some success: I no longer am greeted with the docker error immediately upon trying to finalize the Project Setup.
I will let you know if the problem persists, but in the meantime you can consider my issue closed. I will tag the question as Resolved.
Cheers
