Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Issues with intel galileo iotkit-agent test
I've been trying to connect to intel iot analytics with my galileo gen 2 and I was following this tutorial
https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics# testing-network-connectivity https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics# testing-network-connectivity
I got to the test connection section basically got this error message
root@galileo:~# iotkit-admin test
2016-01-11T13:08:28.328Z - info: Trying to connect to host ...
2016-01-11T13:08:28.956Z - error: Data Submission Error code=ECONNRESET
2016-01-11T13:08:28.980Z - error: Connection failed to dashboard.us.enableiot.com
I read that the issue might be to do with my firewall or proxy, but i have no proxy and i don't think its an issue with firewall
Any ideas ?
Carlos_M_Intel
Hi PeachyDinosaur,
What is the output of running the commands uname -a and systemctl status iotkit-agent?
How are you setting your network? Are you using conmman?
Are you able to ping to a website?
Please check that there aren't network issues in your configuration.
Charlie
JFaul1
Hi CMata_Intel,
I followed the same tutorial as PeachyDinosaur and ran into the exact same error.
I can can ping a website without any troubles. I'm connected to my wifi (no proxy) using connman (I followed this tuturial to do this: https://www.youtube.com/watch?v=4BDLbwUOlLE Enabling WiFi on an Intel® Galileo Board - YouTube).
uname -a output:
root@galileo:~# uname -a
Linux galileo 3.8.7-yocto-standard # 1 Tue Jun 9 22:07:14 GMT 2015 i586 GNU/Linux
and systemctl status iotkit-agent:
● iotkit-agent.service - iotkit-agent
Loaded: loaded (/lib/systemd/system/iotkit-agent.service; disabled)
Active: inactive (dead)
Jan 18 22:12:43 galileo systemd[1]: Stopped iotkit-agent
I would appreciate any help.
Julia
Carlos_M_Intel
Hi Julia,
Try updating your image, you can download the EGLIBC microSD card image from: https://software.intel.com/en-us/iot/hardware/galileo/downloads IoT - Intel® Galileo Board Download | Intel® Developer Zone.
After this, you should get after uname -a: Linux galileo 3.8.7-yocto-standard # 1 Tue Sep 29 22:16:33 GMT 2015 i586 GNU/Linux
While setting your network, use connman (you have to use your WiFi name and password):
root@galileo:~# connmanctl
connmanctl> enable wifi
connmanctl> scan wifi
connmanctl> exit
root@galileo:~# cat << EOF > /var/lib/connman/wifi.config
[service_wifi_b4b6765faaf0_4d7957694669_managed_psk]
Type = wifi
Security = wpa
Name = MyWiFi
Passphrase = MyPassPhrase
EOF
[From: http://www.malinov.com/Home/sergey-s-blog# LSB-compliant-Image Sergey's Blog - Malinov Family Web Presence [LSB Compliant Image Section]
If you still have problems run systemctl restart iotkit-agent
Charlie
Carlos_M_Intel
Hi Julia,
Do you have updates on this? Have you tried with the latest image version for Galileo?
Charlie
JFaul1
Hi Charlie,
Yes, I have tried with the latest image that gave me the expected result on uname -a and it seems to be working perfectly so far now.
Thank you.
Julia
Carlos_M_Intel
Hi PeachyDinosaur,
Have you been able to connect the board to the Intel Analytics Cloud?
Charlie
Community Manager
Sorry for the the delayed response but my laptop decided to break and so I wasn't able to check the outputs of the commands you suggested. Yes I was able to ping sites using a WiFi connection and I used conmman to set it up.
