Community
cancel
Showing results for
Search instead for
Did you mean:
FLean
It's possible to increase PWM frequency?
Jump to solution
Hello;
I'd like to know if it's possible to increase PWM frequency up to 10KHz in Intel Galileo Gen2 WITHOUT using Arduino IDE.
Regular PWM using MRAA-Python generates frequencies about 500Hz.
I know that regular GPIO has more high frequencies. Using MRAA, I've got 20kHz in the pure wave, but when i tried to manipulate the waveform using usleep, the frequency fell to 1KHz.
I'm using intel-iot-devkit-egclib image
asss
Valued Contributor II
1. Galileo Gen2 hardware design limits a regular PWM's frequency up to 1526 Hz.
2. usleep does not allow to have a stability.
3. Using a lightweight Linux version like https://www.zephyrproject.org/ https://www.zephyrproject.org/ instead of intel-iot-devkit-egclib may provide a better stability.
4. It is better to use an external PWM chip with Gen2. For example like https://datasheets.maximintegrated.com/en/ds/MAX31790.pdf https://datasheets.maximintegrated.com/en/ds/MAX31790.pdf
BR,
xbolshe
asss
BR,
xbolshe
FLean
Thanks for the answer, xbolshe. I'll discuss with my research group these points.
Another question i have is if it's possible to access the GPIO's registers directly. If it is, how I do that? Via assembly code?
asss
yes, it is possible. But it will be a little bit harder because of a pin multiplexing.
Actually a language does not matter: Assembler or C.
It is more important to have an experience with a hardware and Linux kernel.
One more way is own PWM kernel driver.
BR,
xbolshe
FLean
Ok.
About the mutilplexing:
I could work on the multiplexers in a more high-level language approach, like Linux Shell and then using C/Assembly for specifically work with the GPiO pin and interruptions. Do you think it could work?
Community Manager
