Community
cancel
Showing results for
Search instead for
Did you mean:
AMasc2
JDK 64 bit on 32 bit machine (Windows 10)
I am under Windows 10, 32 bit. I would like to install Eclipse as IDE to develop Intel Edison and I am following the tutorial here: https://software.intel.com/en-us/installing-the-eclipse-ide IoT - Installing the Eclipse* IDE | Intel® Developer Zone. You request to me to install a 64 bit version of JDK1.8. But it seems there is no way: if I try to install the 64 bit version of JDK, the OS blocks it.
Could you please give me suggestions?
Thank you!
Matthias_H_Intel
Yes, that definitely won't work. You can't install 64-bit SW on a 32-bit OS.
In general Windows 32-bit isn't supported. You may get it working however. There are threads on that topic somewhere in this forum as far as I recall
AMasc2
Hi and thank you for help.
I agree with you but it is strange: I am following the guide to install Eclipse (IoT) for Windows 32 bit. The guide says:
https://software.intel.com/en-us/installing-the-eclipse-ide IoT - Installing the Eclipse* IDE | Intel® Developer Zone:
Java* SE Development Kit 8: Eclipse depends on a Java* Runtime Engine (JRE) to execute. You can run Eclipse with an earlier version of the JRE or Java Development Kit (JDK), but you must have the 64-bit version of Java SE Development Kit 8 (also called JDK version 1.8) to access the full range of Eclipse's capabilities. This includes the ability to create and run IoT projects in Java.
You can download the JDK fom Oracle at http://www.oracle.com/technetwork/java/javase/downloads/index.html http://www.oracle.com/technetwork/java/javase/downloads/index.html. Install the 64-bit JRE or JDK (indicated by x64 in the download name), not the 32-bit (x86) version.
EDIT: I can't find the thread. Could you link it please?
EDIT: I have just found
Matthias_H_Intel
A, sorry - seems I was wrong about the support for 32-bit Windows. Ok, then I'd assume it's a cut&paste error telling you to install the 64-bit JRE. I'd suggest you'd try with the 32-bit version? My 2 cents
Carlos_M_Intel
Hi ago
Have you been able to install Eclipse in your machine?
Charlie
SStra10
Hi I have the same problem, I can't find any help on how to get Eclipse working on a 32-bit machine ... doesn't seem possible - any help?
Carlos_M_Intel
Hi Scott,
The IDE is intended to be used in a 64 bit configuration. You can try to install a 32bit JDK but you could have problems in the future.
Have you tried to force the installation of the JDK for 64 bit in your PC?
Charlie
SStra10
Hi Charlie,
Thanks for your response.
The 64-bit version would not install, I think I'll just have to get a virtual Linux machine running on my laptop.
Scott.
